I've had my rsb for 2 weeks now and today was the first time that
Old Jul 9, 2002 | 10:19 PM
  #41
freeze2k2's Avatar
Originally posted by Tanman
The parking block on the first pic you posted earlier threw me off. You are pretty close to the ground. Some parts of the Addco rsb look like they hang a bit low. Maybe you should get the Stillen bar, it's more uniformly parallel. If it scrapes, the whole bar will scrape!
Ive never seen the addco bar, sure makes me glad i bought the stillen, fits awesome.
Old Jul 10, 2002 | 04:01 AM
  #42
wdave's Avatar
Re: I've had my rsb for 2 weeks now and today was the first time that
Originally posted by ms.thicknes
I drove with it AND with a full load of ADULT passengers
it was a horrible and horrendous event and I am never carrying more than myself and ONE other passenger ever again.
EVERY single damn nook and cranny and bump and dip made the rsb scrape
and scrape
and scrape
and scrape
I actually stopped and pulled over cause I thought I was driving with a friggin flat. AND YES i already had the rsb adjusted once because of the scraping over speed bumps and it has been fine for 4 days
but a full load of passengers was just horrible....
anyone else have this problem
Ok, looked at your pictures, fix is simple - just move the passenger side (only) bracket 3-4 inches toward the center of the car or until the noise stops (you'll need a ballast crew for testing).
Old Jul 10, 2002 | 04:45 AM
  #43
ms.thicknes's Avatar
Re: Re: I've had my rsb for 2 weeks now and today was the first time that
thanks wdave...i'll try it this weekend
Old Jul 10, 2002 | 07:30 AM
  #44
MaxRU's Avatar
How will relocating the bracket affect the RSB performance?
Old Jul 10, 2002 | 10:24 AM
  #45
KLOOGY's Avatar
L33t BMW Drivah
I have pictures on homepage of my Addco, and the clearance I get . Like I said before it clears with no problem with a car load of people, and Maxspeeds. I think that my 17's make it stand higher. As far as needing ramps, and jacks, My buddy and I installed it without even lifting the car at all, and my car is lowered ! I think that Thicky, should have her suspension checked out... That does not sound normal at all !
Old Jul 10, 2002 | 10:43 AM
  #46
Nick Exxon's Avatar
I'm planning to install mine on Saturday morning, and I was wondering if anyone did the job without jacking the car. Guess Kloog' answered that one for me! First handling mod; can't wait!
Buzz
Old Jul 10, 2002 | 10:58 AM
  #47
exunaja's Avatar
Re: Not at all on my Max...
Originally posted by MichaelAE
I drove to Whistler, 4 hours or so, with four adult passengers and a trunk full of luggage and didn't get one scrape on the whole drive. Car was practically bottomed out on the back end, but the RSB did not scrape.
ditto
Old Jul 10, 2002 | 11:07 AM
  #48
hawkdog's Avatar
scrape and install
My Addco RSB was making the clunking noise over bumps too, but if you inspect it closely it should be easy to see where it is hitting. Mine was hitting on the corner of one of those flat plates that the U-Bolts go through. It was easy to see, since the corner of the plate was bent where it had been hitting. All I did to fix it was file down the corner of the plate that was hitting and it was fixed.
For the install, you don't need jacks. Find a curb and hang the butt of your car off of it...you'll have plenty of room to get in there. Make SURE you set your e-brake and leave it in gear too.
Old Jul 10, 2002 | 11:55 AM
  #49
wdave's Avatar
Re: Re: Re: I've had my rsb for 2 weeks now and today was the first time that
Moving the bracket toward the center of the car will slightly decrease it's effectiveness but stop the noise. The real problem is that the bar was designed for the 95-99 where the transverse link is in front of the axle and never fixed for the 2k+ where the bracket's behind.
Old Jul 10, 2002 | 12:09 PM
  #50
Y2KMaxGXE-R's Avatar
do you have any undercarriage rubbing if the car is lowered?
Old Jul 10, 2002 | 12:53 PM
  #51
MaxRU's Avatar
Re: Re: Re: Re: I've had my rsb for 2 weeks now and today was the first time that
Is it ok to move only one bracket? Or do both brackets have to be symmetrical(sp?) ?
Old Jul 10, 2002 | 01:46 PM
  #52
soundmike's Avatar
Very sound, Mike
Now he tells me! I just came from KMart to get those $17 metal ramps. I guess i can always return these
Old Jul 10, 2002 | 01:59 PM
  #53
nope....car is not lowered yet....my suspension is still stock as far as springs/struts go
i am gonna look under there today to see what part of the metal looks worn and then file it down
and also not carry a full load anymore
Old Jul 10, 2002 | 04:21 PM
  #54
Tanman's Avatar
Let me use them too
Old Jul 10, 2002 | 04:23 PM
  #55
KLOOGY's Avatar
L33t BMW Drivah
Sorry Mikey !
Old Jul 10, 2002 | 04:38 PM
  #56
soundmike's Avatar
Very sound, Mike
Tan, sure thing man! Btw, would you by any chance happen to stop by McDonald's on Kirby/59 the other day?
Kloogy
Old Jul 10, 2002 | 06:05 PM
  #57
Tanman's Avatar
Kloogy
I don't eat at McDonald's. It's fine dining or nothing for me!
Old Jul 10, 2002 | 06:10 PM
  #58
soundmike's Avatar
Very sound, Mike
bbbuuut... i thought McD's was the ultimate in fine dining?
Old Jul 10, 2002 | 06:53 PM
  #59
KLOOGY's Avatar
L33t BMW Drivah
Maybe Ms.Thick's passengers have been taking too many trips to McDee's ! They are WEIGHING her ride DOWN !
Old Jul 10, 2002 | 07:23 PM
  #60
we were on the way TO lunch!!! we hadn't made it there yet!!!
smartass
Old Jul 10, 2002 | 08:58 PM
  #61
00MaxSE's Avatar
Pointy Elbows
I just ordered mine through the GD. My '00 SE has stock suspension and stock 17s. Do you think mine will scrape?
Old Jul 10, 2002 | 09:20 PM
  #62
soundmike's Avatar
Very sound, Mike
If installed properly? Nope.
Old Jul 11, 2002 | 04:01 AM
  #63
wdave's Avatar
Re: Re: Re: Re: Re: I've had my rsb for 2 weeks now and today was the first time that
asymetric is ok.
Old Jul 11, 2002 | 11:15 AM
  #64
00MaxSE's Avatar
Pointy Elbows
What is the correct spacing for the mounting brackets? Or will the instructions they give me say that?
Old Jul 11, 2002 | 03:03 PM
  #65
Spartan5's Avatar
ok...here is the pic of my addco rsb
HOLY COW...the bracket on the right is WAYYY too far over.
I had this problem for the longest time. The clunking occurs when the suspension part above the axle hits the U-bracket that goes over the top of the axle. If you get down under the car, you can see on the right side U-bracket where the arm of the suspension has been scraping against it. I loosened the bracket and slid it WAY in (a couple inches), and then I loosened the left side so the bar would be balanced. I used a soft mallet to bang it along the bar, and moved it far enough to guarantee that the arm above would clear the bracket no matter the load on the suspension. Since the arm is only on the right side, the left bracket is unaffected, but I slid it in so the set-up is symmetric.
The clunking used to be so bad that passengers would jump in surprise as I'd go over bumps, thinking my car was a busted-a** piece. After I did this, I test drove it with three fatsos in the back, and no clunking. Haven't had a clunk since. And the bar still performs well, and the car is solid as a rock.
Good luck to you.
Old Jul 11, 2002 | 05:09 PM
  #66
thanks for the suggestion I will try it tonight to see if it will make a difference!!
Max8
Aug 15, 2015 07:06 AM
Trin1j23
Aug 12, 2015 08:31 PM
yat70458
Aug 3, 2015 01:16 PM
