2003 Infiniti G35 Rear Calipers $90.00 shipped
These are the ones you can use with a maxima for the rear. You'd need vented rotors off of G35 or the Z. I never had the time to do this and with Wilwood up front I believe the breaking is adequate. They are 2 piston rear calipers.
hold on were they two pistons, now that i recall, they weren't . gotta get them out of the basement and take pictures.
They were single piston design but the caliper had much greter piston area. In addition these allow you to use vented rotors instead of the solid skinny stuff we have in our maxies. No bracket was needed, this is basically the same thing deuski did.
They are Single Piston like you said a little bigger from the OEM maximas.
You must been the bracket as well so that the Vent disc will have clearence.
IF anyone purchase these and are looking for the rotors hit me up.
There are no brackets needed. It bolts right on according to Deus. The caliper will accommodate the vented rotors as it does in its original application on G or Z vehicles.
I tried fitting the VENT rotors and the bracket that holds the calipers ,would not clear the vent rotors.
You can run the Z calipers with OEM rotors
if you want I can take pics to prove this, Im just giving you heads ups up
HA ok whatever dude , did you even try putting them on NO !
I have done something wrong ? in my 14 years as a mechanic you think I can manage to put brakes on the wrong way ? I wasnt born in Haiti or Mars
just to prove that your taken word from someone and hasnt done the swap.
This is your OEM typical 350z Vent rear Rotors
This is your OEM Maxima Bracket
If you already know so , the Maxima OEM rotors are much thiner than a VENT rotor, So obliviously the vent rotors are wider and DO not clear the brackets from the Maxima.
http://forums.maxima.org/4820947-post32.html
This Thread shows that Dues purchase a FULL calipers meaning it comes with the Bracket , you can see how larger the Bracket is compare to the OEM maxima.
You didn't get the original post and made wrong assumptions. I have FULL calipers for sale and the no need for bracket refered to as repositioning bracket that is normally used with BBK like willwood for example.
Here is a picture of a bracket that was used to get Wilwood Calipers installed up front. A bracket of this sort is NOT needed, whether you've been a mechanic for 15 or 40 years.
I haven't put them on because I am DONE modding. I still have an HID fog lights conversion kit and a roof spoiler that I purchased about 2 years ago waiting to be installed. These two things are the last things I am going to do on this car along with painting the roof black.
you posted rear Calipers , as I assume Calipers only , you never posted it as a Full calipers or pictures. Thus when you said you DO not need brackets this is why I said you do to clear the vent rotors.
I seen others purchase the calipers off 350z and they werent aware of the brackets.
Huttig2009
Sep 25, 2015 03:31 PM
BobMax
Aug 19, 2015 04:39 PM
wingsfan24
Aug 15, 2015 07:35 PM
RealityCheck
Aug 5, 2015 06:18 AM
