CA FS: Maxima Timing chain tensioner repair parts for TSB NTB07-042c
Old Oct 27, 2011 | 12:13 PM
overseaz's Avatar
Was going to install this on my 04 maxima but ended up trading it in.
Which is why I haven't been around here lately.
I bought this straight from my local dealer, paid $187.
Asking $140 shipped. Local pickup is ok too.
Feel free to text or call me (916)218-2843
Includes all parts listed on the TSB NTB07-042c
Link to actual PDF: http://ww2.justanswer.com/uploads/fi...e_bulletin.pdf
Here is the TSB Description:
Applied Vehicles:
2004-2008 Maxima(A34)
2004-2008 Altima (L31) with VQ35 engine ONLY
2004-2009 Quest (V42)
Description: VQ ENGINE; BUZZING / WHINING NOISE FROM TIMING CHAIN AREA
There is a buzzing / whining noise coming from one or both secondary timing chain /camshaft sprocket areas. The noise may increase with engine speed (RPM).
IF YOU CONFIRM:
There is a high frequency buzzing / whining noise coming from the secondary timing chain
system.
• The noise should increase in frequency with engine speed (RPM).
• If the noise does not increase with engine speed, the timing chain system may not
be the cause. Refer to the appropriate section of the Electronic Service Manual (ESM) for further diagnosis.
ACTION:
1. Replace both secondary timing chains and both secondary timing chain tensioner “shoes” with the ones from the PARTS INFORMATION section of this bulletin (on Page 2).
2. Change the engine oil and filter.
3. For repair procedure, refer to the SERVICE PROCEDURE section of this bulletin (starting on Page 3).
IMPORTANT: The purpose of ACTION is to give you a quick idea of the work you will be performing. You MUST closely follow the entire SERVICE PROCEDURE (starting on Page 3) as it contains information that is essential to successfully completing this repair.
Nissan Bulletins are intended for use by qualified technicians, not 'do-it-yourselfers'. Qualified technicians are properly trained individuals who have the equipment, tools, safety instruction, and know-how to do a job
properly and safely. NOTE: If you believe that a described condition may apply to a particular vehicle, DO NOT assume that it does. See your Nissan dealer to determine if this applies to your vehicle.
PARTS INFORMATION
DESCRIPTION PART NUMBER QTY
Engine Oil Filter 15208-65F0C 1
Oil Pan Extension Front Seal 11121-7Y000 1
Drain Plug Washer 11026-01M02 1
Secondary Timing Chain 13028-ZK01C 2
Tensioner Shoe 13097-ZK01C 2
O-Ring, Front Cover 15066-2Y510 2
O-Ring, Front Cover 15066-5E510 2
Crank Shaft Seal 13510-7Y000 1
ThreeBond 1217F (sealant) 999MP-1217FPP (1) (2)
(1) As needed (shop supply).
(2) ThreeBond 1217F (sealant) is available from the Nissan Direct
Old Nov 19, 2011 | 09:55 PM
Nismo_max04's Avatar
Still available?
Old Nov 23, 2011 | 05:49 PM
overseaz's Avatar
Yes its still available.
Call or text if interested...
(916)218-2843
First $120 Takes it!
Old Jan 30, 2012 | 04:37 PM
overseaz's Avatar
This is SOLD
maxinout93
Oct 27, 2015 01:29 PM
Team STILLEN
Aug 10, 2015 04:29 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
