k&n filter
Old Aug 4, 2003 | 05:25 PM
DiRtY ThIrTy
k&n filter
anyone who has put in the k&n replacement filter, did u stick on the "gaskets" that came with them...i did but i was wondering if it made a difference, i mean i could always take them off...and also did anyone notice a significant difference?
Old Aug 4, 2003 | 05:32 PM
Alpha Max's Avatar
are the k&n filters out for the 6th gen max if so were did you purches it from.
Old Aug 4, 2003 | 05:39 PM
CanadianMoFo's Avatar
I first saw them forsale at http://www.courtesyparts.com/maxima/a34.html
Someone else here said that they are the same filter as another Nissan vehicle so they should be easy to order from anywhere that sells K&N.
CM.
Old Aug 4, 2003 | 06:20 PM
Glude's Avatar
Guys that actually have these, did you feel any increase in power? I still think a modified stock intake will make the most power.
Old Aug 4, 2003 | 06:46 PM
For sure a modified intake will produce more power! Duh.
For $45 a K&N filter is a cheap way to get an air filter in there that you can rewash for the rest of the lifetime of the vehicle rather than buy paper ones once or twice a year.
I had a K&N style filter in my last vehicle. I'd say there was very little increase in power if any. And if there was any it was all at the top end, so it wasn't noticeable with my butt dyno. I suspect that the same is true with the 04 Max since the intake is relatively well designed in the first place.
The major benefit, apart from the rewashing of the filter, would perhaps be an increase in gas mileage. I got an extra mile per gallon out of the last filter I had. Fuel economy is a good thing.
CM.
Old Aug 4, 2003 | 09:40 PM
SERSPECV's Avatar
any sound difference with the k&n filter..
Old Aug 6, 2003 | 06:48 AM
jbgoodmax's Avatar
Just put mine in last night ...
It doe's sound different. I don't seem to hear that low tone as much
It seems as quiet if not more so.
Now the power is noticable. I guess crisp is a good word. I think this will have more of an affect than people think do to the length wise slots vs the stock width wise.
Old Aug 6, 2003 | 04:20 PM
greg_atlanta's Avatar
K&N lets more dirt in engine (bad long term) and the oil may get on air sensor. Just replace the OEM filter annually.
Old Aug 6, 2003 | 05:15 PM
Asmitty's Avatar
BULL
jbgoodmax's Avatar
The dirt thing???
The reason I changed mine was for the performance, and higher air flow rates.
OEM really needs to be changed twice a year. Once dirt gets on the paper, it "totallY" clogs that section.
With all the testing done on K & N, they would have to be fools to let more dirt in.
Old Aug 7, 2003 | 01:02 PM
DiRtY ThIrTy
nobody answered my question. did u use the gaskets that came with it. i bought mine from autozone.
Old Aug 7, 2003 | 03:56 PM
maxmale's Avatar
i heard the oil off the k&n filters where getting on the maf or sucked into the tb and causing cel's to pop up in the 4th/5th gens i guess it could happen?
Old Aug 7, 2003 | 05:01 PM
It could happen if you really went gonzo on the oil when you were cleaning it out. The instructions say to use very little. I would suspect (and I am guilty of it) that a lot of people use too much oil when re-oiling them after cleaning. I think a lot of that could be cured by waiting overnight for the oil to spread out to the entire filter surface after you spray it on. Its when you do it in a rush that you will end up putting on too much and getting some dropletts sucked into the intake and coating the MAF etc.
There was a kid here in town with a POS riced out Neon that had problems. He was cleaning his filter weekly because he was so "hardcore" that he figured more was better. All he ended up doing was putting a load of oil down his intake. I think that the frequency of cleaning has a lot to do with where you live and the type of driving you do too. For me once a year was plenty for 20-24k km's of driving 50/50 chity/hwy.
I don't think our intake is too hard to get the filter out of . You could throw in the old (clean) air filter while the K&N is pulled for cleaning. That way you won't be in a rush to do it. You can have the luxury of time to dry it out properly that day. Then re-oil and wait for it to completely travel to all the fibers in the filter overnight.
CM.
Old Aug 8, 2003 | 08:00 AM
DiRtY ThIrTy
if anyone has installed the k&n drop in filter, please just let me know if you used the foam stick on gaskets. just curious to know but it would be nice for an answer
Old Aug 10, 2003 | 06:27 PM
jbgoodmax's Avatar
sorry, I was out of town ...
No, it was a straight drop in. The filter number is 33-2031.
It is woth it. I have put several K&N filters in my cars over the years. But, this has been the most noticable power increase (for a drop in).
Old Aug 11, 2003 | 06:24 AM
DiRtY ThIrTy
right 33-2031 is what i bought, but it came with two little foam pieces that you stick on to the sides i guess to seal it, i dunno. should i take them out?
Old Aug 11, 2003 | 06:51 AM
Glude's Avatar
Just put it in and tell us if you felt any gains at all.
Old Aug 11, 2003 | 07:55 AM
DiRtY ThIrTy
no noticeable gains.
Old Aug 11, 2003 | 08:22 AM
QuikSilver04's Avatar
Just a K&N probably won't register any changes on the butt-dyno. I did have a '98 Silverado Z71 a few years back and I swapped the stock air filter with a K&N. Couldn't tell any difference when I first did it, only way I could tell it made a difference was when I took it out and put the stock back in right before I sold it. Boy, talk about it being a dog afterwards. Made it really sluggish when I punched it and it lost alot of top end.
Best way to tell if it helps any, drive the p*ss outa it with the K&N for a week or two, then swap the orig. back in. See if it makes a difference then
Old Aug 11, 2003 | 09:06 AM
specv's Avatar
im gonna get one.. does it sound alittle better with the filter?
Old Aug 11, 2003 | 09:07 AM
DiRtY ThIrTy
imo, its actually a little quieter
Old Aug 11, 2003 | 11:26 AM
specv's Avatar
quote:
right 33-2031
this is the part # to the filter, is it for a 04 maxima?
Old Aug 11, 2003 | 05:51 PM
Glude's Avatar
Now i dunno if i wanna buy this or throw a K&n cone filter on the end like 04ELITESE. maybe he can shed some light on his lil rig and tell us how it performs??
Old Aug 12, 2003 | 11:15 AM
Deven2kStickMax's Avatar
you need to use the gaskets, otherwise unfiltered air will get into the engine and you know what that can cause?? I'm using Fram part # CA4309, which gives a nice tight fit and works good.
Old Aug 12, 2003 | 11:39 AM
DiRtY ThIrTy
i had the gaskets in there, but yesterday took them out it was actually a better fit. the filter is the same size as the OE so i didnt think they were necessary. i also talked to a tech from nissan who said its not necessary. however, if it is necessary, how do i go about getting them now, cause they were stick on and have no glue left on them?
Old Aug 12, 2003 | 06:17 PM
http://www.knfilterchargers.com/sear...appsearch.aspx
Putting in the right year make and model shows that the K&N site lists two different part numbers:
33-2031-2 Cartridge
33-2259 Non-Cartridge
Anybody know what the difference is?
CM.
Old Aug 12, 2003 | 06:42 PM
bluemaxx's Avatar
Moderator GT-R
33-2031-2 Cartridge
CM.
Well... 33-2031-1 or 33-2031-2 seem to fit all kinds of Nissans for 10+ years.
Enter 2003 Sentra instead of 2004 Maxima and the 33-2259 pops up on there too. Also check out 2004 Sentra.
Old Aug 12, 2003 | 07:08 PM
Weird.
Old Aug 12, 2003 | 09:16 PM
Jaws's Avatar
I didn't use the gaskets either as the panel fits perfectly.
Old Aug 14, 2003 | 11:12 AM
ga2000's Avatar
whats cartridge and no cartridge??
Old Aug 14, 2003 | 12:01 PM
DiRtY ThIrTy
one is the filter for air purification behind the glove box and the other is for air intake...
Old Aug 14, 2003 | 03:04 PM
ga2000's Avatar
i would want the one for just air intake right??? i just want the normal everyday drop in filter.. which one is it?
Old Aug 15, 2003 | 05:33 AM
DiRtY ThIrTy
33-2031-2
Old Aug 18, 2003 | 01:44 PM
ga2000's Avatar
so alot of u didnt use those two tabs, that it came with, i feel if it fits in there it shouldnt be a problem right?
Old Aug 19, 2003 | 09:35 AM
ga2000's Avatar
should this be right if it does fit like the stock one do i have to put the tabs on? on and one more thing does the computer take time to register the new filter? its just a drop in..
my03maxima
Jul 28, 2024 07:40 AM
Justin Kroll
Oct 1, 2015 07:03 PM
Redfox
Sep 28, 2015 10:41 AM
bumpypickle
Sep 20, 2015 08:22 AM
