'04 SE Automatic 0 - 60?
Old Aug 7, 2003 | 08:01 PM
lock22's Avatar
Can anyone site a source or provide a link that tests this model 0-60?
Old Aug 7, 2003 | 08:19 PM
MONTE 01&97 SE's Avatar
The only official test was in Consumer Reports in either the May or June issue, it was 6.8 secs.
Old Aug 8, 2003 | 12:13 PM
c2003k's Avatar
Consumer report 6.8 secs???????
Old Aug 8, 2003 | 04:06 PM
Yes Consumer Reports they did Sports Sedan comparo that month including the G35 sedan which also got 6.8 sec dash to 60.
Old Aug 8, 2003 | 04:26 PM
c2003k's Avatar
seems kind of SLOW
Old Aug 8, 2003 | 04:36 PM
vandy786's Avatar
My friend's G35 is not as fast as I thought it would be. Another friend (Oxidizer6) has a 2003 Maxima SE auto and I think his is noticeably faster. As for the Consumer's Report 0-60 times, I would not pay it much attention. It could be like the time when some magazine or website got 7.4 s when everyone else was getting 6.18, 6.2, and 6.4. Time for some second and third opinions.
Old Aug 8, 2003 | 07:35 PM
MaxMaybe's Avatar
A 6.8 0-60 time from Consumer Reports is a GREAT sign.
They are ALWAYS slower than the car mags and if that's what they got, it means that C&D would have managed to squeak a 6.5 out of the same car at the least.
And, since C&D got a 6.2 out of the six-speed, a sub-seven second time for the auto should be achievable by anybody.
Old Aug 8, 2003 | 08:09 PM
vandy786's Avatar
Oops, I forgot to mention that those numbers at the end of my last post were for a 2002 Acura TLS.
Old Aug 8, 2003 | 08:13 PM
lock22's Avatar
http://www.consumerguide.com had 0-60 times (all automatic) as follows:
04 Maxima SE - 7.1
03 Accord EX - 7.0
03 Altima SE - 6.9
03 TL type S - 6.8
I guess any source or site with "consumer" in the name has slow times; however, seeing the Maxima (albeit very close numbers, but still) at the bottom of this list is quite depressing.
Old Aug 8, 2003 | 09:05 PM
bluemaxx's Avatar
Moderator GT-R
04 Maxima SE - 7.1
03 Accord EX - 7.0
03 Altima SE - 6.9
03 TL type S - 6.8
I'm hanging my head in shame right now. Three tenths of one second. So if you were using the 'thousand 1, thousand 2, thousand 3 method to time them the difference between the TLS and Maxima would be "thou."
Old Aug 10, 2003 | 01:58 PM
specv's Avatar
i think the auto max se will do 0-60 in 6.5 or so, and the stick will do low 6 seconds..
Old Aug 10, 2003 | 02:24 PM
Driver72's Avatar
Well first off, Consumer Reports getting a 0-60 in 6.8 seconds is quite good from them. Keep in mind, I don't think they "adjust" their times for "Optimum" conditions. So, that's a respectable real world time. "Adjusted to optimum conditions" ie: sea level, temp., zero wind, low humidity, etc etc. could mean 6.4-6.5 from them.
Now, let me say this:
The Maxima SE auto won't be that much slower than the manual really.
The auto has VERY good gearing.
It's first gear is a 4.657:1
That's very low and great for acceleration.
Even it's second gear of 3.032 is very good.
Lastly, let me say this:
According to the acceleration computer calculations, the 04 Max SE with the 5 speed auto should achieve a 0-60 time of 6.31 seconds in ideal conditions!
This is probably quite accurate.
The 03 Altima SE with it's 4 speed auto shows a 0-60 time of 6.85
The 03 Maxima SE with it's 4 speed auto shows a 0-60 time of 6.77
The 04 Maxima SL with the 4 speed auto shows it's 0-60 time of 6.84
So, again, without correcting for optimum weather conditions and sea level and the like, and without perfect launches, you can expect to see 0-60 times that are in the upper 6's for the auto SE.
Old Aug 10, 2003 | 02:30 PM
specv's Avatar
thats not bad... im just thinking should i nail it off the line or just tap it, than nail it so i dont burn up the tires and slow me down...
Old Aug 10, 2003 | 02:49 PM
Driver72's Avatar
Don't just nail it, you will just spin the front tires too much.
Brake torque just a bit (computer says 900 rpm's is best for this car) and then apply the throttle swiftly but without "nailing" it to the floor.
Try a couple different ways anyway, but powerful FWD cars will just spin too much, that won't get you good 60ft times.
You want to spin a bit to get the revs up and keep from bogging down, but you want the tires to "hook up" rather quickly and then get as much power to them as possible without breaking loose again.
Honestly, you'll probably find your 60 ft times will be in the 2.3-2.6 second range depending on a few things.
Old Aug 10, 2003 | 02:58 PM
specv's Avatar
i never brake torqued a front wheel drive car, rear wheel drive yeah, but i guess it does work with front wheel drive... if u guys think 900 than ill do 900 rpm and get on it.. but the tire presure im not sure about yet..
MaxStock
Dec 5, 2016 05:19 PM
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
2kmaximel
Sep 16, 2015 03:19 PM
