Little problem about the hid light
Old Nov 4, 2003 | 03:14 AM
alan8888's Avatar
When I buy this car I didn't have the Hid xenon option. Now I want to install the after market. Hid Kit. Anyone know that what kind of bulb r we using. R we using the H4 bulb or h7 ?
Old Nov 4, 2003 | 09:39 AM
CanadianMoFo's Avatar
The bulb numbers are all in the user manual.
Prepare to be quite entertained when you are removing the entire bumper to get to the headlamp assembly to change the bulb.
Old Nov 4, 2003 | 10:03 AM
silverbullet's Avatar
I didn't get the HID either. How much is the aftermarket kit, and what does it consist of.
Old Nov 4, 2003 | 04:33 PM
ny96max's Avatar
contact Freddie aka. 97gles here on the Org. He sells IMO the best HID kits. The run around $380+ or so shipped when i last checked with him.
hope that helps!
Ant
Old Nov 4, 2003 | 05:22 PM
bigcozz's Avatar
Make sure you get a good HID kit that installs well becuase you dont want to have any leakage or condensation that might cause bulbs to go. My advice get the infor on teh nissan part and then compare to the aftermarket available.
Old Nov 4, 2003 | 05:58 PM
I've not been able to find any aftermarket headlight bulbs for the 04's yet. Only specs on the OEM bulbs from GE.
Old Nov 4, 2003 | 10:19 PM
alan8888's Avatar
OH i bought the H4 catz kit with high/low....did I bought the wrong one.
I bought it in ebay ?
Old Nov 5, 2003 | 08:37 AM
The factory bulb is a 9012. If thats the same as an H4 bulb I'd be really suprised. Good luck with your H4 kit. Let us know how the install goes.
CM.
Old Nov 5, 2003 | 10:36 AM
Kzmaxima's Avatar
I Just Replacement HID Bulb 6000 K by Philips ...look cool more purple...The Factory HID Bulb by OSRAM XENARC D2S made in Germanny.Fog light Replacement by PIAA Super Plasma H3
Old Nov 5, 2003 | 12:33 PM
MAXSE-RIOUS's Avatar
Hey there Kzmaxima!
Interesting to see that you've replaced your fogs with PIAA Super Plasma H3's. I just bought a pair of the same PIAA's and want to swap out my fogs also. But I'm having the toughest time figuring out how to get at the fogs??
Would you be willing to give some instruction on how you got to the bulbs to swap 'em.
Thanks much
Old Nov 5, 2003 | 06:20 PM
You might be able to get at the drivers side if you remove the battery and part of the intake.
The passengers side is a different matter. I can't get at it to change my DRL that burned out. The dealer says its about a 3 hour job. The entire bumper assembly has to be removed to get at the last bolt that holds the assembly in. I tried myself. I removed all the bolts I could around the headlight and it wouldn't budge.
CM.
Old Nov 6, 2003 | 09:53 AM
Kzmaxima's Avatar
Removal and Installation:
1...Remove all 6 clip on the top front fascia...take the front facia out
2...Remove 2 screw (black) under neath bumper
3...Remove all clip splash shield cover
4...remove 2 screw (white) in side the bumper....bumper have to be remove out of fender
5.... remove all 5 screw head light unit (2 on the top, 2 under neath 1 left,1 right....1 at the side fender)
6...pull the combination lamp up and toward the front of the vehicle..
....orther side head light do the same,.......... take 2 hours
Old Nov 6, 2003 | 10:14 AM
Thanks Kzmaxima for the step-by-step.... but holy crap!, I never would have thought that it would have been designed such that the whole front fascia & bumper must be removed to change a bulb!
I guess this helps prevent theft of our HID's, but it certainly makes simple bulb replacement a 2 hour P.I.T.A.
Old Nov 6, 2003 | 10:51 AM
Kzmaxima's Avatar
you don't have to remove bumper out....just fit the hand to remove the screw at the side fender..
iflexsteel
Sep 15, 2015 03:37 AM
KristyKarina
Aug 23, 2015 09:53 AM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
Samedi
Aug 13, 2015 04:05 PM
