bra - how much, where to get it
I have used 2 different companies. One is Xpel (www.xpel.com) and the other is Chip Guard (www.chipguard.com). They both offer the 3M invisible bra material. I love it. I am on my 4th car with the kit and you barely see it unless you stare. It is pricey, usually $400-$600 installed. The material is the most expensive part. My last Maxima (2000 SE) had 110,000 miles, mostly highway and the front looked brand new.
Clear bra is worth every penny......
Originally Posted by Maxmann
I just ordered the Nissan model. It was about $110 total. From Courtesyparts.com. Actually, my car is the "model" for the bra...check it out! srm
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2455067024
Cheap auction on the OEM Nissan bra. Certainly worth the $30 as long as nobody else bids it up.
Originally Posted by JAKE02
each to their own....but I would never put a reg bra on a car....it will eventually do more harm than good......the cure is worse than the problem.......IMHO clear bra is the solution
Well if you leave it on there all the time you get dirt in behind it. The bra moves a small amount in the wind. Combine that movement with the grit and it equals sandpaper.
The bra shouldn't be used in rain. Just for nice weather. Take it off and clean the backside frequently. Thats all you have to do. I only leave mine on for road trips. Around town it's pretty much useless. Its not a big deal to take it off and on.
In the long term, using the bra constantly may result in uneven paint fade.
CM.
CM.
Never had a problem with the OEM bra which I had and still have on my cars. 87 Max(miss the gadgets still in this car and lazy boy style seats),89 Max(bad weather car still),95 Max(lemon),96 300zx(wifes),97 Max(traded),01 Max(totalled), current 03 Max and 03 350z.
doctorpullit
Apr 23, 2017 05:35 AM
ramtin325i
Aug 8, 2015 05:13 PM
