2004 Maxima Rear View Mirror
Hey all,
I picked up one of these mirror and I want to fix it in my ride, (doesn't have this mirror) .. I found out which pins at the back do what but is there a way I can test this out to see if it turns on? Anyone know what kind of voltage is required? I tried testing it out on a 9 volt battery but had no luck. Any info would be very much appreciated!
Thats a good question.
Of course a 9V battery isn't going to work. You'll need a 12V source. One 9V plus two AA's will work.
The downside is that if you put voltage to the wrong pins there is a possibility you could burn out the circuitry in the mirror.
Beyond that advice I can't help ya.
CM.
CM.
Well, I tried hooking it up to my ride and it wouldn't turn on. The power source I used was from my fuse box. It was the radio fuse. Funny thing is I smelled something burning. I immediately turned the car off and unhooked the back wires. I know the mirror wasn't frying because I smelled it immediately and it smelled normal. Maybe it was the wires? Too much power? Someone help!!
I finally got everything to work.
How do I configure the compass though?
When I press and hold "comp" I have the option of selecting a number between 1 and 15. What does this mean?
P.S Also, does this have tempature reading because when it first boots up I can see the Farenheight and Calcius icons at the top right part of the screen.
No idea. All mine does is auto-dim and have the Homelink buttons built in. Perhaps someone with the package that upgrades the mirror to the same style as yours can help you out.
Maybe visit a dealership and take a peek through the manual of a showroom Maxima.
Oh I see, so I should face north for example and play with the number until it gives me that reading.. Thanks.
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
wingsfan24
Aug 15, 2015 07:35 PM
