Can I remove these or will water leak???
Old Mar 28, 2004 | 03:03 PM
Chris_RI's Avatar
Hi all,
The molding on the bottom of the door panels, can this be removed without causing harm to the car. It looks like this molding was designed after the car was made, it does not look like this was Nissans intentions when the car was initially designed. Anyways, has anybody removed these? I took one off, sprayed with water and didnt notice anything? its just glued on with one with a few screws. I want to know if I can remove them all for good, Thanks
<img src = "http://68.14.19.186:81/images/MAXIMA2004/NissanMaximaSE2004_5.jpg">
Old Mar 28, 2004 | 03:04 PM
Chris_RI's Avatar
http://68.14.19.186:81/images/MAXIMA...maSE2004_5.jpg
Old Mar 28, 2004 | 08:36 PM
lightonthehill's Avatar
Chris - Not sure which molding you are talking about, but it doesn't really matter, as Nissan is not going to the trouble and expense to put anything on a vehicle unless there is a reason.
The molding is there to keep water away and/or to reduce the outside sound entering the car. Those are the two normal uses for door molding.
Old Mar 29, 2004 | 07:15 AM
Chris_RI's Avatar
This is a horizontal piece of plastic, painted the cars color, and slips on the bottom of the doors held by glue and a screw and come caps. I just think the car would look nicer without it. just my thought.
Has anybody removed these? any problems?
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
Socalstillen
Sep 20, 2015 11:46 PM
brichi
Sep 14, 2015 05:23 PM
Hdnseek
Sep 9, 2015 05:55 AM
