what octane gas?
Old Apr 17, 2004 | 07:20 AM
biggestbelly's Avatar
what octane gas?
in the booklet it says to use at least 87 octane. But inside hte gas door it says use 91 for best performance. Im just curious what u guys use.
Old Apr 17, 2004 | 07:48 AM
kipburgess's Avatar
I've been using 92, but during the winter I used 87. But with the knock sensor I don't think it really matters which grade you use. I know I couldn't tell any difference between the 2.
Old Apr 17, 2004 | 07:49 AM
04_LiquidMax's Avatar
ran 87 in winter and I'm only gonna run 93 the rest of the year if gas prices dont jump up. I'd say run 93. I got about 17 mpg in city with 87 and i get 21-22 mpg in city with 93.
Old Apr 17, 2004 | 07:50 AM
thanks alot for the replies
Old Apr 17, 2004 | 08:09 AM
Monotaur's Avatar
I use 93 as well.
There is a place in Springfield, MO that has 120 octane though... a few months ago it was about $4.25 a gallon too.
Old Apr 17, 2004 | 09:59 AM
KCMAXX's Avatar
KC's FINEST
I only run 93. Monotuar you in KC?
www.cardomain.com/id/kappsmax
Old Apr 17, 2004 | 11:57 AM
Redsand187's Avatar
That's leaded though, and will damage your emmision devices.
I've only used premium... 91 sometimes 92 depending on the station. Out here in the west we get screwed.
Old Apr 17, 2004 | 03:52 PM
kb0uy's Avatar
Normaly the octane is determined by the refinery. Missouri has a state truck comming around sampling fuels about once a year. Varifying octaine and water content.
Old Apr 17, 2004 | 07:34 PM
JiuJitsuThug's Avatar
Premium all the way. But we only get 91 octane out West that I know of...
Old Apr 17, 2004 | 09:15 PM
Monotaur's Avatar
Nope, about an hour east of Springfield on I44.
Old Apr 17, 2004 | 09:57 PM
vqman
where do you find 93 in KC?
I can only find 92, and that is only at BP/Amoco.
my 5th gen could use some 93 octane love..
-vq
Old Apr 17, 2004 | 11:29 PM
lightonthehill's Avatar
biggestbelly - Whatever octane you settle on, do not switch back and forth. The Maxima computer takes several tankfuls to adjust between octanes, so frequent switching means the engine does not get fully adjusted to one octane before another is put in the tank.
Old Apr 19, 2004 | 07:15 AM
CHASE_BXMW's Avatar
Sunoco Has 94 Octane Premium Fuel
Old Apr 20, 2004 | 11:25 AM
gujucrave's Avatar
I only put 93 Octane in my 04 Sl. When I bought it the dealer said "don't put anything less then 93 Octane".
Old Apr 20, 2004 | 03:21 PM
SMX95's Avatar
always use highest octane because the engines are new and also high octane takes longer to burn so it wont waist as fast yet it creates a better combustion which means more response, hp ratio from your engine. Some engines wont even start with low octane, but to be on the safe side and if you really want your car to run great over time then use 93-94 octane.
Old Apr 23, 2004 | 07:17 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
where do you guys pickup this crap?
Old Apr 23, 2004 | 07:49 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
LOL ture SteVTEC. 93 octane burns slower lol....
Old Apr 24, 2004 | 04:03 AM
SMX95's Avatar
heres a direct quote from another car forum. "on most cars that are rated for use of 87 octane, there is no benefit to using higher octane fuel. the higher octane is basically a slower burning fuel so that it won't detonate (knocking) prematurely."
Im not looking to start any flaming i do mechanics in my school been doing it for 3 yrs and know for a fact that higher octane burns slower than 89 or less octane. Be my guest and do a research but that "LOL" and "where did u get that crap from" wasnt needed. Just do a research before you want to start up a flame.
http://forums.vwvortex.com/zerothread?id=1313222
Somewhere in the middle
Old Apr 24, 2004 | 04:08 AM
SMX95's Avatar
heres another quote from a MPT forum "Fuel with higher octane ratings burn slower...that's IT. Buring slower allows the timing to be advance for better performance."
http://forum.mpt.org/messages/9/2448.html?1063044185
Scroll all the way down
Old Apr 24, 2004 | 04:16 AM
SMX95's Avatar
this quote has to deal with gains of higher octane and the knocking noise i mentioned.
High octane fuels allow engines to produce more power because they allow more spark advance before pre-ignition occurs. It is of no benefit to put 100 octane fuel into an engine that doesn't have the spark advance dynamic range to take advantage of it.
Under warm cruise (closed loop) strategy, EEC will push the spark advance out to the point where trace knock is detected, and then back the timing off slightly, to keep away from pre-ignition. This strategy makes sense to get the most efficient burn and the most power. Under these conditions, you may hear some knock if you mash the gas, because it takes EEC a few CPU machine cycles and crankshaft rotations to drop out of closed-loop strategy and retard the timing.
Under wide-open-throttle (WOT) conditions, EEC is not looking at the knock sensor because the engine is simply making too much noise for the knock detection strategy to filter out the knock signal from the noise. Timing and fuel for WOT is derived from lookup tables that are vectored primarily by crankshaft RPM and engine coolant temperature, and to a much lessor degree by the mass air signal.
Under most conditions, EEC should be able to get the most out of any reasonable fuel that you pump into the tank, however, an especially bad load might be beyond the range that the spark lookup tables can compensate for, so pulling the octane shorting bar invokes a new set of tables, with less aggressive spark advance curves for WOT operation.
http://www.shotimes.com/SHO3gas.html
Im done doing research.
Take care and I hope you both understand that higher octane does burn slower.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
