How to Remove Manual Shift Knob
Old May 12, 2004 | 11:36 PM
Edify11's Avatar
How to Remove Manual Shift ****
Ok, this is probably a real dumb question. How do I remove the manual shift ****?
Old May 13, 2004 | 09:29 AM
CanadianMoFo's Avatar
Duh, unscrew it.
"Lefty loosey, righty tighty" is the phrase to think of if you need help remembering which way to turn it.
Old May 13, 2004 | 10:01 AM
Edify11's Avatar
Just wanted to make sure. Wasn't sure if there were any clips or anything.
Old May 13, 2004 | 10:02 AM
RaTgoesMaX's Avatar
Some of these mothers are glued on, so try with one of those belt type grips so as not to mark or damage the leather and if that doesn`t work have the dealer do it.
Old May 13, 2004 | 11:03 AM
mailjbrown's Avatar
I remember reading somewhere that there is a small button or pawl that has to be depressed allowing the **** to pull off vertically. I tried to find the reference, but could not locate it.
Old May 13, 2004 | 12:16 PM
RaTgoesMaX's Avatar
That is the procedure to remove the headrests but the ***** are threaded to screw on the shaft.
Old May 13, 2004 | 12:58 PM
04SEelite's Avatar
There is on the **** with the 5sp Auto, but not on the 6sp Manual - check with the dealer to make sure that you don't strip it trying to get it off...good luck.
Mar 12, 2020 12:06 AM
Cotozic
Sep 23, 2015 11:55 PM
Socalstillen
Sep 20, 2015 11:46 PM
2kmaximel
Sep 16, 2015 03:19 PM
