replacing interior trim
Old Jun 17, 2004 | 02:21 AM
cameek's Avatar
Does anyone know a good site to find oem matching color interior door/stereo trim replacements (was moving some stuff and they got scratched). also, if anyone has done it, is it easy to do yourself?
Old Jun 17, 2004 | 02:50 AM
SilverBelle04's Avatar
This might help you if you don't find replacments:
http://forums.maxima.org/showthread.php?t=312897
There are a lot of sites for overlays, but i havn't found any for replacements other than the oem ones.
Bob
Old Jun 17, 2004 | 06:06 AM
Mystery's Avatar
There are auctions on ebay selling the trim, but as far as finding a kit that matches the SE trim i haven't been able to find one.
Old Aug 5, 2004 | 06:05 PM
SilverSixth's Avatar
Bob
SilverBelle, for some reason I can't see the pics you originally posted. What did you use to paint the trim with? Thanks!
Joe
Old Aug 6, 2004 | 03:43 AM
Joe - I'll repost the pics tonight after work.
Bob
Old Aug 6, 2004 | 03:19 PM
Joe - As requested:
Before:
The paint that i used:
After:
I also gave the trim a few coats of clear coat from the same paint manufacturer.
Let me know if you need more details.
Bob
Old Aug 18, 2004 | 07:29 PM
Chris_RI's Avatar
I may try this paint on all the trim, since it scratches so easy, does it look stock?
I called dash comapnies and they all saud the max can only have overlays, not molded trim because of the crappy design of the interior. :-(
Old Aug 18, 2004 | 07:58 PM
xpmax's Avatar
Since the car HAS molded trim, I don't understand why there can't be aftermarket molded trim???
Old Aug 19, 2004 | 03:06 AM
If you do it right..it looks totally stock. That's why i posted a pic that included the door handle and the trim. The door handle is the stock paint. I re-did all of my door trim pieces and then coated them with a few coats of clearcoat. They look great and are very durable.
Bob
Old Aug 19, 2004 | 06:14 AM
Chris_RI's Avatar
what was your process of doing this? If its really durable with the clear coat, we should paint the shifter plate area. How did you find out about this paint, and the same color etc.. Also, I wonder if its more durable than stock, like will bug spray remove the paint again?
Old Aug 19, 2004 | 02:18 PM
All i did was bring a trim piece into the autoparts store and I matched the paint by eye. I had my wife, the colour expert, check it when i came home. I wet sanded using 800 grit until very smooth. I sprayed a couple of coats of colour and then a few coats of clear. I only did it to one trim piece and let it dry to see if it really matched the colour. I had my wife check the result too. She gave me the thumbs up and i finished the other 3 pieces. This was a couple of months ago. Not a scratch on any of them.
Bob
Old Aug 19, 2004 | 03:15 PM
CanadianMoFo's Avatar
Bob, are you going to paint your lower grill the same way too? Get crazy with the spray can!
Old Aug 19, 2004 | 04:08 PM
I was thinking a nice bright neon orange spray paint for the lower grill.
Bob
Old Aug 19, 2004 | 04:43 PM
Bob,
Thanks for posting the photos! Let me run this by you. I would like to paint the door handle cups, trim around the window switches, etc. Do you think it will look okay and be durable?
I have frost interior and those trim pieces really look cheap. I was thinking about doing the vent trim as well.
All opinions welcome.
-Joe
Old Aug 19, 2004 | 06:35 PM
Originally Posted by *******
Bob,
-Joe
I think that it would be okay as long as you take your time. Make sure that the pieces are well sanded and mooth as a baby's butt.
Spray in very light coats. Many light coats are better then a couple of thick coats.
Bob
Old Sep 9, 2004 | 05:15 PM
Max Cat's Avatar
Joe - As requested:
Before:
After:
Bob
Hey Bob,
What auto parts chain did you find this stuff at? I can't find it at AutoZone or O'Reily here locally.
TIA!
Old Sep 9, 2004 | 06:15 PM
Hey Max Cat,
I bought mine at Canadian Tire way up here in Ottawa, Ontario.
The Duplicolor site says you can buy it in these stores:
http://www.duplicolor.com/solutions/wheretobuy.html
If you can't find it locally, PM me and i'll see what i can do to help you out.
Bob
Old Sep 9, 2004 | 07:07 PM
Max Cat's Avatar
Thanks! I have 2 more locals to try tomorrow, but if I have no luck I'll give you a shout. I did buy a can of "millenium Silver" from WalMart and it is verrrrry close, but a shade brighter and with some light shiney speckles in it. I could get away with it, but I'd always know and it would drive me nuts
Old Sep 10, 2004 | 01:53 AM
Sounds good. Let me know. BTW...that's a nice line-up in your laneway.
Bob
Old Sep 10, 2004 | 06:23 AM
Max Cat's Avatar
Bob
Thanks! They do seem to play well together. It's so cool to have 2 vehicles that have the same controls in the same places, nav that works the same in both, and share similar DNA styling-wise. The "cutout" part of the Armada grille ALMOST makes the Max's bucktooth look right when they're sitting next to each other.
Hey, maybe I'm on to something here. Somebody at the Armada factory said "hey, what do we do with all these dumb bucktooth looking cutouts from the Armada grille?"
Old Sep 10, 2004 | 09:56 AM
msoemax's Avatar
Bob,
I got my car back from the dealership and noticed a huge scratch on the passenger side. I want to do what you did to your trim, I see you hand sanded the molding with 800 grit paper, did you do the entire trim peice or just where it needed to be painted?
I was wondering if you could maybe post a pic taken during the day with no flash to avoid the flash reflection? I need to paint the trim. I am so mad at the dealership for scuffing my car up. The interior is so f#@%ing cheap. I know, common problem to all
Thanks bob
Old Sep 10, 2004 | 03:03 PM
Originally Posted by msoemax
Bob,
Thanks bob
Actually i did all 4 door pieces whether they needed it of not. But the front driver's side was very bad. I sanded the complete pieces and painted the whole thing. Then i did a couple of clarcoats over it. Havn't had a single scratch since.
I'll take a pic tomorrow in good light and post it.
Bob
Old Sep 12, 2004 | 12:52 PM
Here are pics from today. No flash, just regular daylight:
Trim and including the door handle for comparison:
Close up of the trim:
Hope this helps.
Bob L.
Old Sep 28, 2004 | 02:25 PM
maxzma's Avatar
I'm bumping this back up because I want to ask SilverBelle04 if the paint on his trim is still holding up? I have some scratched areas on my passenger door trim and I am considering doing this if it works and holds up.
So, SilverBelle04 does it still look good?
Old Sep 28, 2004 | 03:47 PM
Looks awesome and has stood up beautifully !
Bob
Old Sep 28, 2004 | 03:57 PM
maxzma's Avatar
Great. Sad that we have to resort to this but if it works I'll try it!
Thanks!
Old Sep 28, 2004 | 04:18 PM
carcus's Avatar
Thanks!
Well, there are other options such as a custom dash. Depends on how deep you want to dig in your pockets. This company is not too cheap, but they can make some nice real custom carbon fiber kits or other to go over what you have and no worry about paint or scratches. It is a pretty extensive kit, but the real stuff will cost you a bit. On my BMW I had a nice real silver carbon fiber interior....loved the hell out of it. When I have money to blow, going with a silver carbon fiber kit to go over what I have. This is just to give you an idea that there are other options out there.
http://www.wowtrim.com/index.asp?Pag...OD&ProdID=7658
http://www.aaaexoticwood.com/form/colors.htm
stevesmax
Dec 17, 2020 11:57 AM
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
Maxilano
Aug 31, 2015 07:33 PM
cstrasz
Aug 27, 2015 08:07 AM
