Auxilary Power Outlets
Old Oct 17, 2004 | 06:06 AM
Yama1yzf's Avatar
My auxilary power outlets do not have power when the key is turned off. I know in my old Aurora, there was a fuse that had to be jumped to make them on with the key off. Does anyone know if that is the case on the Max? Does'nt say anything in the manual. Thx.
Old Oct 17, 2004 | 08:03 AM
rabenoja's Avatar
that could be a simple solution but, there might be other electronics running off of that same circuit. Which means that they too would be seeing constant power. The way I did it was just to cut the lead coming to the outlet and then I wired in a constant 12v power source directly to the outlet.
I did a write up with the wire colors needed and where to run the wire a few months ago. If you do a search you might be able to find it.
Good Luck.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
