Flappen' License Plate
Old Nov 30, 2004 | 09:38 AM
unclemax's Avatar
I've been reading this group for awhile...it's great!
Anyway, I bought a chrome license plate frame but my '04 SE only came with the top screws. So it's not held down at 4 points and whenever I open the trunk or hood the thing flaps and rattles like a piece of sh*t!
where can I get decent screws to use on the bottom? I don't want any rust spots or problems, don't to drill new holes.
Anyone solve this??
Thanks,
Unclemax.
Old Nov 30, 2004 | 09:42 AM
Smoken'04's Avatar
I bought a smoked plate cover through PepBoys. I then bought a screw set that comes with a special allen wrench to lossen and tighten them with. I have no problems with them what so ever.
Old Nov 30, 2004 | 11:30 AM
joe_mo1971's Avatar
One thing you may want to check is that the plate is inside the bottom two notches of the frame. If it is inside and the top screws are tight, it should not rattle.
Old Nov 30, 2004 | 12:13 PM
CanadianMoFo's Avatar
My plate cover is only held on by two screws at the top edge. It used to rattle a bit. I took some of that cheap foam water pipe wrap and cut a small piece off. I used some double sided tape, and stuck it to the back side of the plate. No more rattles. Its been on there for the last 4 months or so. Cost me next to nothing and about 5 minutes of my time.
CM
Old Nov 30, 2004 | 12:29 PM
mailjbrown's Avatar
I used the double sided foam tape - no more rattles!
Old Nov 30, 2004 | 09:10 PM
lightonthehill's Avatar
Like others here, I cannot tolerate rattles. I put little clear soft plastic 'nipples' (meant to put on the back of picture frames to protect the wall) on the back of both bottom corners.
knight_yyz
Nov 1, 2015 01:34 PM
ricky7780
Sep 24, 2015 06:50 PM
-ReLLiK-
Sep 8, 2015 12:02 PM
