Door Panel Removal
Old Jan 21, 2005 | 07:41 AM
patang's Avatar
Door Panel Removal
I would like information on how to remove the rear door panel. I had to replace the rear door window (someone tried to break into my car). The window was replaced by the dealer, but the pieces of broken glass were not removed from the door internals. When the rear door is closed, I hear pieces of glass moving around.
Thanks !
Old Jan 21, 2005 | 07:54 AM
viguera's Avatar
I'd say take it back and have them do it right... there are things to disconnect from the panel before you take it off, so you might end up worse off than where you are now...
I know the PDFs for the removal are around somewhere... someone sent them to me a while back but I can't find them right now. I'll look at home and see. IIRC it's two pages, one for the front and one for the rear.
Old Jan 21, 2005 | 08:11 AM
msoemax's Avatar
I only supplied the front door removal, but the same steps apply for the rear doors too. Find some thin, yet non-flexible plastic flat head screw drivers to get under the plastic. I used some bicycle tire remover tools to get everything apart. You will also need a phillips screw driver. It should take you 1-2 hours to get it all done. I agree about taking it back to the dealer. You paid for them to do the job, make them do it the right way!
ef9
Sep 29, 2015 11:29 PM
95naSTA
Sep 21, 2015 06:50 PM
lkiller123
Sep 21, 2015 03:00 AM
carid
Sep 17, 2015 05:00 AM
