LED Tails
Ok this first pic is my car with the normal bulbs in them. As you can see the spread is pretty good. Fills the entire assembly up top.
http://www.doc-tv.net/maxima%20pics/IMG_0177.JPG
Now you can see it with the LED bulbs in. They do not fill the assembly with light like a tradition bulb. But I still like them. These pictures stink, if you saw them in person it looks better.
http://www.doc-tv.net/maxima%20pics/IMG_0181.JPG
Here you can see where I mounted the RL-650 Load Resistor. It circled it in blue. I used liquid nail. Hope it holds. You have to use a resistor or the turn signals flash at a very fast rate.
http://www.doc-tv.net/maxima%20pics/IMG_0184.JPG
One last pic of the LED brake and turn signal. The turn signal and the brake lights both double as taillights as you can see here. Its not the best pic in the world. For some reason the LED's just don't take good pics. They must be shy of the camera.
http://www.doc-tv.net/maxima%20pics/IMG_0204.JPG
Please forgive my dirty car. Winters been rough in the Chicago burbs this year and salt is everywhere. Its sickening I know. I got the car washed earlier in the week but it obviously doesn't get cleaned under the hood. I will do that this spring.
http://www.superbrightleds.com/cgi-b...gi?product=CAR
3157-25 LED bulb
25-LED 12VDC replacement bulb
Dual Contact Wedge Base
Unique Design has 19 LEDs aiming out the end and 6 radially mounted LEDs aiming 90 degrees from the base for better lens fill
Select Red or White LEDs
$ 7.95
3157-25 LED bulb
$ 7.95
Without the resistor the turn signal looks like its on crack. Its a bit too fast.
Ok this might sound strange. But if you have the headlights on during the day and use the signal. Its actually quite dim looking. The LED's low and high brightness don't differ much. At night its plenty and no big deal. IF the headlights are off the difference between it being off and then flashing on is real noticeable so its fine.
Lesson here, if you want LED. Don't use your headlights during the day, makes the signal harder to notice.
his post said "Select Red or White LEDs" unless it stated color elsewhere.
Only if you use the LED for blinkers will they flash rapidly. I only have it installed in the top part of the tail light. I'm waiting for that resistor to come in so I can put them on the blinkers.
the top is the tail light, the bottom blinks. I only have the top in so far.
here is a clip of the light so u can see that the bottom blinks (my camera skills suck though!) http://www.putfile.com/media.php?n=100_0320
as far as the out come, yeah I like them, although the standard light still produces a little more light when you have the brake pressed.
since the stock bulbs are white light, how come they tell us to get the light bulb that matches the outer shell. Wouldnt a white bulb shine more than a red colored one?
Originally Posted by jreilly04
i am also debating to buy the white or red bulbs..... Any suggestions.... and do u need a load resistor for each side meaning you need 2 right.
Wow, thread back from the dead!!! I went with red, read the how to I put together...
http://forums.maxima.org/showthread.php?t=455704
The ones I found since then are way better and brighter.
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
which exactly are stop/blink/lights on?
