Unplug Battery For 1hr Resets Service Engine Light?
Old Feb 26, 2005 | 05:24 AM
04BlackMaxx's Avatar
i READ ON A FORUM ABOUT NISSAN TITANS THAT THESE GUYS UNHOOKED THE BATTERY AND LEFT IT FOR A FULL HOUR TO RESET THE SERVICE LIGHT AFTER DOING MODS, ANYONE HEAR OF THIS BEFORE? ILL TRY IT BEFORE MY SERVICE DATE ON TUESDAY, JUST WONDERING.
Old Feb 26, 2005 | 05:54 AM
SkoorbMax's Avatar
Yes I've Heard Of It And Yes It Works And Why Are We Screaming?
Old Feb 26, 2005 | 06:05 AM
Im at work and we always type in caps and i forgot to shut it off...well as i said im at work so i have 11 more hours to kill up here so i went down to the garage and unhooked the battery. Ill go down in an hour or two and reconnect it, it was worth a shot even if it dosent work. If it does, and i put the K&N back in, then left the battery off for an hour BEFORE starting the car, is this the proper procedure to avoid these problems?
Old Feb 26, 2005 | 08:26 AM
No, it doesnt do anything..Had it unhooked for 3 hours and still no luck. I guess tuesday its gonna need to be reprogramed or something.
Old Feb 26, 2005 | 07:11 PM
Mystery's Avatar
Definatly doesnt work. After my intake made the check engine light go on, we tried it and it never worked. Some cars it does, just not ours.
Old Feb 27, 2005 | 06:37 AM
SO what did you do mytery man? I think im in the same boat as you were...Im not even gonna touch it...too nerve wrecking. Did you have the dealer reset it with a computer? I have the stock panel filter back in to the dealer does not question me.
Old Feb 27, 2005 | 10:57 PM
Mystery's Avatar
Actually i was told to give it some time to adjust. And after 2 weeks it went off.
Old Feb 28, 2005 | 01:27 AM
ramberg's Avatar
GrandPa
I had to have the computer reprogramed when the engine light would not go off. It read a code 6. It took like 45 min for the job to be done and I was not charged. Later Warren
Old Feb 28, 2005 | 06:56 PM
kevin7r's Avatar
You have to disconnect both terminals. Trust me. I just reset mine a month ago.
Old Feb 28, 2005 | 08:16 PM
It went off on its own after 4 days for some reason...with the stock panel filter back in.
Old Mar 1, 2005 | 02:07 AM
Mystery's Avatar
Maybe you just got lucky. We disconnected everything and it never solved anything.
Old Mar 1, 2005 | 09:40 AM
msoemax's Avatar
It really depends on the code you end up tripping. Some of them are critical ones like the Airbags. If it was a MAF sensor you may or maynot be able to reset it. You can try disconnecting both leads and see what happens. I don't know if this will work or not. It's worth a try.
BTW autozone does checks for free...sometimes the guy is cool and can reset it for you.
Old Mar 1, 2005 | 08:56 PM
Well thankfully as i said...it went off by itself and has been off for a couple days
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
