Front Engine Near Grille Components
Anyone!
Need some assistance. My 2005 MAX was involved in a accident...basically a guy in a F250 ran me, my Wife and 2 1/2 year Daughter off the road...I had right side quarter panel damage and bumper damage. The body shop put the car back to together but forgot some of the cosmetic plastic parts on the top of the grill, directly in front of the radiator.
What I'm looking to find out is that, one I have a ECG Grille. Just like the stock grill it connects on the top on the right and left. It connects with a plastic screw type device on the top. What I need to know is...is there a black plastic part that goes over the painted portion on both sides? The body shop didn't put these back on and the portion of the grille that goes over it or under it is loose. See pic below..I put a yellow circle around the plastic top parts in questions...thanks to SilverBell...this is his photo I used to explain this...
http://memimage.cardomain.net/member...049_1_full.jpg
If I'm correct, a normal stock grille or ECG grille that I have goes over this and one of those plastic clips, clips right in...thanks for the input ahead of time...
Jimbo
Jimbo
Originally Posted by Tek-Niq
this thing right above the date lower right hand corner..
small but helps.......... sorry so dirty......
Jimbo
I tooh the other post out thinking he meant the air inlet above the radiator..
Jimbo
Hey Maj Jimbo, Those black pieces of plastic are missing. The E&G grill sits on top of those pieces of black plastic should be nice and snug. My E&G sits snuggly attched with the palstic rivets/screws. The E&G grille has tabs just like the stock pic above.
Looks like yours are missing.
Good luck with it.
Bob
Good luck with it.
Bob
Good luck with it.
Bob
Good luck with it.
Bob
Jimbo
P.S. - SilverBelle...hope you don't mind I used your photo for example purposes...I didn't have a before shot of my engine compartment....
Jimbo - no problem - glad to help...i'll see if i can see a part number when i get home from worlk...........
Bob.
Bob.
Jimbo
I took another look under the the hood after work while it was still light. I can't see any numbers on the blck pieces. My E&G sits on top of the black and fits snuggly on both sides.
Jimbo
Do you have a pic of yours ?
Jimbo
EDIT: Silverbelle...here is a pic of the engine compartment...look at the far left and right and you'll see the grille is attached directly to the painted area. From what I remember, it fit very snug...now there is almost a 1/8 of a inch of space between the grille portion and the painted portion being held by the cheap clip. Let me know if this makes sense.
Oh...I know the plastic part between the radiator and the grille that covers the top over the hood latch is missing. The body shop did put it on, but it was missing clips and was scratched up and they ordered a new one....
I'm going to take a good look tomorrow morning at mine and get back to you. Its too dark right now where my car is to see anything.
From your pics it looks like the black piece is painted whereas mine is black ??? I'm starting to think that its all part of the bumber piece, but looks like a different part because of the way it is black from the factory ?
Is it possible the push pins holding the grille are not fully pressed in or have been weakened by the accident impact ? Or maybe they used the worng ones ?
Like i mentioned i'll take another look tomorrow morning and let you know.
Jimbo
Originally Posted by MAJ_Jimbo
Good questions SilverBelle...it is possible the plastic pins are weakenend probably from taking it off again and putting it back on. They are ordering new one's and should be ready tomorrow to put on. Well...check if your parts are indeed painted black and not a cover over that area. Kinda weird that Nissan would paint that black when it's all one component of the front bumper. This whole thing really stuck out when my front grille was making bumping noises when I was driving it back home from the body shop and thats when I found missing plastic pins, the top plastic part was scratched and not attached right and the right and left of the grille attached in the area in question was very loose. Let me know what you come up with...thanks!
Jimbo
Jimbo
I guess I should have asked this before, but for other 2005 Max owners...do you have a black plastic cover in question on the left and right of your grille that your grille is connected to...basically on top of it? Look at the previous post pictures to see what I'm talking about...
Till then...I'm at total loss....
Jimbo
Matt93SE
Apr 8, 2018 09:23 AM
vingodine
45
May 21, 2016 12:46 PM
cmpowell86
Aug 10, 2015 12:35 AM
