Staggered Rims
Old Mar 20, 2005 | 08:01 AM
04BlackMaxx's Avatar
Staggered Rims
Is it possible to run this combination on the 6th gen? Something such as 19x8 in the front with a 45mm offset, but a 19x9 or 19x10 in the rears with a 20mm offset? Am I dreaming and need to wake up?
Old Mar 20, 2005 | 08:07 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
the front is ok, but the rear will prob rub the inside wall.... the wider the rim, the more offset you need...
I don't know how much we can go in the rear, but 20mm offset is just too low I think..
the less offset, the rim gets closer to the inside wall.... increase the offset to the same rim and it will pull away from the inside wall...
Old Mar 20, 2005 | 08:19 AM
Tek-Niq's Avatar
like I said I dunno how far we can go, but front 19x8 @ 45mm offset, and rear 19x10 @ around 38-45mm offset sound abit doable...
unless someone could correct me on that....
Old Mar 20, 2005 | 08:27 AM
DeusExMaxima's Avatar
The Street Concepts Maxima runs with staggered rims and tires. I think it has like a 20x8 and 20x9.
Old Mar 20, 2005 | 08:35 AM
Tek-Niq's Avatar
it doesn't matter how big they are.. cause you can run 22x8 no prob, but you can't fit 22x9.5 though.. it all matters on how "wide" the rim is.. the width is what causes the rubbing not the height....
Old Mar 20, 2005 | 11:44 AM
I dont want to exceed 20", but I want to stagger the setup if possible, and have as small of an offset possible with the rears for an obvious deep dish look. Something that would enhance handling, rather than hinder it. Im lookin at BBS, I love the european racing look and the lightweight.
Old Mar 20, 2005 | 12:05 PM
Tek-Niq's Avatar
I understand.. you want a deep dish look.. you can do it, but not with a 10'' wide rim.. I don't have any knowledge on what to recommend on this matter..
I do know, the less the offset "20" the closer the rim gets to the inside wall.. remember that.. you might have to go with a 19x8 and go with a 20mm offset.. do some more research though, I'm not sure..
Old Mar 20, 2005 | 11:57 PM
05MaXiMaMenG's Avatar
post some pictures up, im interested in the staggered rim thing too. Im lOOking at the RH Revolution J8 those are bad *** Yo
Old Mar 21, 2005 | 07:35 AM
andymax95
i have 20x9 all around and no rubbing whatsoever with the drop
was gonna go staggered with 20x9 up front and 20x10 in the rear, but then someone told me the max is front wheel drive>
Old Mar 21, 2005 | 08:43 AM
Jayzmax04's Avatar
HA! True!
No need with the FWD. Also, when it comes time to rotate......
Old Mar 21, 2005 | 08:57 AM
NismoMax80's Avatar
SuPeRmOd
even with the logical reasons previously stated, if you still feel the desire to do so, guess you can go to a shop and try wheels on to see what works and what they can do.
Old Mar 21, 2005 | 10:59 AM
Yeah I guess if 20x9's are ok I could do that at all 4 corners and be happy, they have rims which still have a deep lip but not a very low offset. Why would the lower offset bring the inner sidewall closer to the car? It seems it would be the opposite, and the wheel would stick out more on the sides. Because what happens if you flip the rim and put it on backwards, you then have a -45mm offset and the rim is then sticking 7.5" outside the car, right?
Old Mar 21, 2005 | 11:10 AM
Jeff92se's Avatar
I'm needing a caw
Fit? Maybe. But I'd wonder why anyone would want their car to understeer even more than before
Old Mar 21, 2005 | 08:02 PM
Too bad I just got a set of F1's for my stock rims. Ill have to wait till something turns up in my job search to spring for 20's, then I guess Ill be puttin this set up for sale. Blaxima's maxima is exactly what I wanna go for.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
