I hit 6K rpm for the 1st time today...
...problem was, I still had it in "P" (Park)...
well, I was in a hurry to leave work this afternoon that I accidentally hit the gas pedal instead of the brake! hehehe... anybody done that? is that good or bad?
Wouldn't there be less stress on the engine/other components while in park than say flooring it while driving and letting it bump up against redline? I mean, 3500 lbs is a lot of weight to pull...
I was in my old company car one time it was an old Honda accord, I had on some large boots, and Put it in reverse and accidently hit the gas with the brake and floored it... It peeled out of the space swinging the rear end in all directions luckily i didnt hit any cars, i was close though.
Originally Posted by boone
I'd like to see the answer to that question too. I have heard that it is bad to rev the engine when a car is cold because the oil hasn't warmed up so it won't lubricate the engine components like it should.
I know of at least 2 cars that were damaged by accidentally stomping on the gas in park and needed repair. I certainly see if it's a cold winter morning to be concerned. I did this in the old Buick after driving. With all it's other problems, it's still running.
For our Auto, while driving atleast, it's not possible to redline. But I don't know about 5th gear, Park, or Nuetral. I surely wouldn't do it often, but if all sounds normal after one time, I wouldn't worry. You should be fully broken in by now and I agree full throttle while driving seems just as hard on it.
I wouldn’t worry too much about it, red line is just that, a danger area to let you know that continues operation in this RPM range could potential cause engine damage. I also agree that high revving when the engine is cold is not good because the engine oil viscosity (lubricants ability to flow) is still thick which means decreased piston/cylinder engine lubrication. For cold starts (including your first morning drive in any temp), the recommended method is to start the car, put in drive, cruise until the engine temp indicator reaches it’s normal, operating point followed by “Feel free to punch it…” Hope the info helps…
is still thick
I take mine to red all the time, it's not as hamrful as you may think. Bouncing off the limter is bad though.
Nismo, so when you say it wont redline while drving, does that mean the TCM doesn't let any of the gears redline, even when shifting the auto "manually" ?
Originally Posted by NmexMAX
Resistance to flow.
High resistance to flow.
Resistance to flow.
Originally Posted by joemax1
Hi, I just have to ask, but what do u mean with your statement: "Bouncing off the limiter is bad though"?
Originally Posted by carcus
Not really the best for an engine. The rev limiter is there for a purpose. Now, if done on not that often, not much of a big deal, but really not good with a car not warmed up. Takes a bit to get the juices flowing. Wonder if the Maxima has the ECU.....I imagine, like some cars with OBD II that act as a black box....the dealer can check things with. I have seen some engines BLOW bouncing off the limiter.....most of them had custom programming though that RAISED the stock limiter a bit. You can tell when it bounces. Never tried on my Max. This car is too new and expensive for me to rag on. That is what a beater is for.
I once went to the 6,200 red line and that was when I was a little angry. I felt the engine gasp for fuel up there and a slight shut off, thus I release my stubborn foot. I got to tell you, the Max picks up on the demand when u want it to.
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
