hazards stopped working!!
Old May 16, 2005 | 12:11 PM
Big Mike's Avatar
Hey is there a fuse for the hazard flashers? Mine stopped working and I thought if there was a fuse I would replace it myself. I looked in the fuse box and under the hood and I didn't see anything. If someone has some info please share.
Thanks,
Mike
Old May 16, 2005 | 01:15 PM
NismoMax80's Avatar
SuPeRmOd
fuses are to the left of steering wheel. there are also a few under the hood. did you check the manual?
Old May 16, 2005 | 03:15 PM
install30's Avatar
what were you doing to make your hazards quit working?????????
Old May 16, 2005 | 04:10 PM
CanadianMoFo's Avatar
Did you perhaps disconnect the wireing harness underneath the shifter cover? If you were working on something under there or on the center stack it needs to be disconnected to get access. I know I've forgoten to re-connect it before.
CM
Old May 17, 2005 | 03:19 AM
Big Mike's Avatar
I haven't modded the car, I really don't plan on it. It just stopped working, I checked the fuses under the hood and in the car. I also looked at the manual and I didn't see any thing that would lead me to the fuses, I just wanted to see if anyone else had this problem.
Old May 17, 2005 | 06:13 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Before you bring it to the dealer, try using this web site, maybe you can find something or contact an online tech for assistance:
http://www.infinitihelp.com/Ownershi...a/Diagnose.htm
Old May 17, 2005 | 06:57 AM
ranjittx's Avatar
That is really a coincidence because I dropped my car off at the dealership for an oil change and also because my Hazards suddenly stopped working.
Old May 17, 2005 | 09:03 AM
Big Mike's Avatar
What was the cause of the problem with the hazards?
Old May 17, 2005 | 04:07 PM
ranjittx's Avatar
I just got my car back and the reason the hazards were not working was because the wires became disconnected. They told me they just re-connected them and they work now.
Old May 18, 2005 | 05:06 AM
Big Mike's Avatar
Thanks for the information, I have an appointment tomorrow to get it looked at. I am also having my brakes checked to since they shimmy when I depress the brake pedal. I think it is the rotors, especially since alot of people here have that problem. As long as it is covered under my warranty I wont freak out.
Old May 18, 2005 | 10:09 PM
BadBlackMaxSL's Avatar
Make sure you let us know what happens. Good luck.
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
MidnightMaxima_22
Aug 19, 2015 01:01 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
