Front Strut Bar Question
Originally Posted by SLuxury
I would go with a strut bar if it has the look you like. They realy don't make too much of an improvement in our handling since our strut towers are almost on the firewall. My opinion is to get the cheapest one that you like if you really must get one.
I want to hear something like this: "I just put one in and I can feel the difference, quicker steering respond. I don't know about other brands, but {if} the bar is hollow it won't do much good." Hope my addition of the word "if" is correct in better explaining what you were saying.
Originally Posted by SilverMax_04
I'm not looking at a Strut Brace to improve the looks of my engine compartment -- I want to improve the handling of my SE in the curves. Do you have a brace on your SL? I'm looking for the opinions of Max owners who have them installed on a 6-generation Max.
Since they are less expensive.
It seems to help plant both wheels down during hard acceleration, anyone else?
received it
Just received my front strut bar and rear sway bar...going to install them and let you know about the ebay one and how good it is. has anyone had problems getting the bolts off, lol? I take it you just take off the bolts at the top of the struts and put the bar on and then replace the bolts?
And I am talking about the front strut bar when I ask about the installation by the way
I also had to slightly bend some AC tubing to elimiate rubbing and used a high strenght tie wrap to keep it in place.
Do you need a torque wrench to tighten it back up? Or can I just use a wrench?
Hollow or solid is irrelevant, the strut bar doesn't act on torsion resistance like a sway bar. The most effective strut bar would be to get a straight piece of metal and have it welded to the strut towers. Like I said, our strut towers are on the firewall, so they don't move... or else you would hear the firewall and rest of the car moving/cracking.
If you want significant improvement in handling without lowering your car, I would get the rear sway bar. In a hard turn, your rear wheels will lose grip before the front.
Trust me, this is my 4th front wheel drive car. I've dumped a lot of money into my past 3 and have learned quite a few things here and there. Not that being an engineer doesn't help.
Here's my last car I got rid of last year:
http://www.mustangmods.com/data/9894/combined.jpg
Just trying to be helpful. Ultimately, it's your decision based off of what you read on this board.
Solid or hollow determinds the flexilibity of the bar under pressure since it is not perfectly straight.
by the way, I don't know about your SL, but on my 05 SE the strut towers are seperate from the firewall, they're not ON the firewall.
Originally Posted by RHMax
I don't know about other brands, but the bar is hollow it won't do much good.
From what I have read, this is not really the case. I remember when Roush racing started using a hollow anti-sway bar on their race cars to save weight. They went on to explain that the rigidity of the bar was not hampered by the fact that it was hollow (as long as it was thick enough not to bend) and it saved a lot of weight.
Of course, I'm not a mechanical engineer by trade so what do I know?
I still dont see any word on the results of the cheapo Ebay CF strut tower brace....but I think chernmax makes a persuasive arguement that stillen is a good choice..I guess If I get it ill just hope it dosent hit the manifold. Did you notice a difference when you ONLY installed the FSTB? I take it you installed it before getting the RSB. However im still interested in how the CF Ebay one went.
Help finding a Front Strut Bar
Hi,
I'm in the search for a cheap front strut bar, aka Ebay bar. I'm not interested in purchasing the stillen bars. Does anyone know an ebay seller who carries strut bars for '04+ maximas? I only found one for the 3.0L Cefiro
1. go to www.ebay.com
2, then in search type "04 maxima strut bar" ???
here's the thread you repost, now as one: ta da!
Originally Posted by minsbang
Hi,
Was there a noticable difference with the stillen as opposed to without? Seems like a pretty cheap mod. Just wondering, will it make the SE ride any stiffer (as to me our cars corner very well). If it does make a big differnce then why didn't Nissan put a $25.00 strut brace there in the 1st place?
Taylor (a modding noob).
The effect on handling will not be quite as dramatic as a rear anti sway bar, which is extrememly noticeable. Nissan did not put one on probably because this is allegedly a "luxury car. I see it as BOTH luxury and performance, and my goal is to explore the performance aspect of the car. I believe strut bars have the effect of stiffening the chassis to improve handling. I have one and even if it didnt function, which by the way I believe it does function, I think it looks pretty darn cool.
Of course I tried that. One ad was for the '04 3.0L Cefiros and the other did state that it's a FTB for Maximas UPTO '04s. I wondered why it wouldn't fit for the '05-'06. So I sent numerous questions to the seller but failed to receive any response.
Stillen only sells it b/c someone went against Stillen's advice and bought the Altima one. This person told Stillen "ah ha, it worked!" so they slapped maxima on the same bar.
For ebay, they have been listed as 00-04. I also asked questions with no replies. I see no way that a 5th or 5.5 gen could fit ours.
Chris (in this thread) got the CF one that isn't available right now on ebay, but hasn't commented further.
A FSTB is mostly a visual mod anyway with our strut towers so close to the engine wall. I'll only get one if Cattman/Progress designs one.
After reading the posts, I'm probably going to order the rears first. If the front is non-noticeable, then why bother, right? I'm not going for the unique engine bay look either. Thanks for the info gents.
Nismo does a good job of listing all of the reasons I have not bought a front strut tower brace. I am very happy with my Catmann rear anti-sway bar, and agree with Nismo -- I'll buy a front strut tower brace when Catmann designs one.
Stillen has it for around $150.
I do not have a answer to the Nissan question.
Pretensions....
Don't forget to pretension the bar by putting it on with your wheels off the ground..
I did it and found it works like a charm ..
However, there was a lot of debate on this concept in the General Forum ...so you all can take it or leave it as you desire.. However, try it and see if it works for you is my recommendation...
So you jack up the car with wheel off the ground and install? Since i have mine installed already, I suppose I can just loosen it, and then jack up the car and tighten, correct?
