Front Strut Bar Question
Old Oct 2, 2005 | 06:57 PM
  #81
blackpaladin67's Avatar
Originally Posted by DeusExMaxima
So you jack up the car with wheel off the ground and install? Since i have mine installed already, I suppose I can just loosen it, and then jack up the car and tighten, correct?
Yup, that is the concept , cannot hurt to try it , I did and it seems to have made the front end on mine a lot tighter... there was a recent thread on the general discussion about it , quite a number for it and of course some against doing it.. Both wheels off the ground ....
http://forums.maxima.org/showthread.php?t=431958
Since then I have also changed the offset by 10 on my wheels and that most definately has had a significant effect .. It is like on rails around corners now..
Old Oct 2, 2005 | 07:30 PM
  #82
NismoMax80's Avatar
SuPeRmOd
Originally Posted by chernmax
Well if your statement is true, than you are only buying for the looks as well? I would still be entertained to see if cattman can do better than stillen, in the end run, it's all about taste...
when i was going to get the Stillen FSTB, yes it was for looks and hopefully some kind of performance. I know if Cattman makes one, it will be thoroughly tested and fitted for the Maxima. Stillen has fitment issues. Seems now that most do not, but a few rubbing the manifold and others the hood was enough for me not to consider it anymore. It was designed on an Altima.
Now if the current discussion (Paladin is referring to in Gen Max) bears true and gains are seen while no adverse affects, then it will also be for performance.
FWD we naturally experience Understeer (did it myself). Tying up the rear (upgraded RSB) can reduce that and even cause Oversteer (w/ RSB have done that). My hopes have been that with a FSTB it can be evened out making the Max Neutral and Roll almost nonexistent.
On Z's we're the towers are mid engine bay, FSTB shows a lot of difference. With our's up against the rear wall, no so much. I've been following the discussion on if to preload or not
Old Oct 2, 2005 | 08:06 PM
  #83
chernmax's Avatar
Nations 1st 6th Gen Turbo
Well it's only been 3 years since 6th gens hit the market, when will cattman finally figure it out??? Again, with the location and fitman issues, I suspect cattman will come up with something exactly like Stillen, however shape it differently and offer it in a different color. Overall, I am in agreement with you, for the front of a 6th gen max, it's all about looks, not a whole lot more. Rear is definitely a different story...
Old Oct 2, 2005 | 08:15 PM
  #84
Mystery's Avatar
I finally got my stillen one after months of backorder and problems with them finally sending it too much. It hasn't done much for me being its in my trunk along with the rear sway, just never got around to putting it on. The one attempt i made we realized we did not have the right tools. Eh maybe one day i'll get to it.
Old Oct 2, 2005 | 08:41 PM
  #85
Had to bend mine becuase my bolt pattern is sitting 10 degrees off the USA bolt pattern , Guess it made it even tighter..
Old Oct 2, 2005 | 09:00 PM
  #86
RHMax's Avatar
Newbie just Registered
A bit tricky too install.
Old Oct 3, 2005 | 10:42 AM
  #87
chernmax's Avatar
Dude , if you put it in the front seat, you may get to it sooner, all you need is a rachet set for the front, the Allen came with mine. As for the rear, 15 minutes at a shop and maybe about $25 clams if you don't feel like doing it. At least with the rear, you will feel a tighter ride...
Old Oct 3, 2005 | 08:16 PM
  #88
Mystery's Avatar
I have a guy at work that does all the installs for employees, i just have to find a free night. I work all day and my sleeping patterns or lack there of never help as well. Maybe when i have my rims taken off i'll just give in and have the shop do it all.
Old Oct 4, 2005 | 06:24 PM
  #89
NismoMax80's Avatar
SuPeRmOd
Soooo,
I felt like bothering eBay auctioneers again:
Was gonna ask again how 00-04 bar fits 04 when they are diff cars... Then remembered how there is no answer, since last time I received no reply.
Item: Front Up FU Strut Bar Nissan Maxima 00 01 02 03 04 (8004913234)
This message was sent while the listing was active.
marsh80 is a potential buyer.
so it doesn't fit the 05 or 06 maxima?
thanks,
Justin
and the response i hoped for:
hi,
sorry, it doesn't fit 05+ year.
thanks
www.tuningpros.com
sooo, obviously the bars doen't fot the 04 either.
Old Oct 4, 2005 | 06:26 PM
  #90
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
AHAHAHAHA!!!! nice.... what an idiot....
Old Oct 4, 2005 | 06:29 PM
  #91
NismoMax80's Avatar
SuPeRmOd
so here is my reply, which I doubt will get a response. (although I banked on their greed with my closure)
Then you know that means it can not possibly fit the 04 either right????
00-03 are similar, but 04-06 is the current model. If I would buy this for my 2004 Maxima, you're telling me it won't fit b/c mine is exactly the same as 05 and 06.
I wish you did make an 04-06 bar. I know a lot of potential buyers.
Old Oct 4, 2005 | 11:28 PM
  #92
RHMax's Avatar
They might start taking orders tomorrow for 6th gen bars and have them on back order for a couple of months
Old Oct 5, 2005 | 07:56 AM
  #93
logik05se's Avatar
Rear Sway
On The Stillen Website, It States That The Rear Sway Bar Will Fit An 04 But Not An 05. Are They Just Out Of There Minds Or Will It Really Not Fit Lol.
Old Oct 5, 2005 | 07:58 AM
  #94
ramberg's Avatar
GrandPa
Thats is correct. Call the on their toll free number and ask them why.
Old Oct 5, 2005 | 08:03 AM
  #95
logik05se's Avatar
ok thanks, there goes that idea then....
Old Oct 5, 2005 | 09:50 AM
  #96
RHMax's Avatar
B/c the 04 is 22mm, and 05 is 24mm. All Stillen REALLY have to do is supply larger bushings, but they'd rather loose the sales. I'm happy w/ Cattman, even though it's a whole 6 pounds heavier than stock (don't know about Stillen's, but hollow tube too). 6lbs on a 3500lbs car, BFD.
Old Oct 5, 2005 | 07:18 PM
  #97
NismoMax80's Avatar
SuPeRmOd
LOL guys hope you know this, I don't know what to do now:
cont. from above #91
hi,
00-04, it is not 00-03. Maxima has changed model from 05 year.
thanks
www.tuningpros.com
Old Oct 5, 2005 | 07:36 PM
  #98
chernmax's Avatar
Too bad about the 05-06 problems with the Stillen, since I have a 04, my Stillen fits, is heavier than stock, is rock solid and I would put it up against a Cattman any day of the week. Anyone who understands engineering characteristics with regard to strengths will tell you, hollow or solid, don't mean $hit when it comes to which would be stronger, Stillen just followed more of an aircraft engineering structural design, nothing wrong with that...
Old Oct 5, 2005 | 07:53 PM
  #99
RHMax's Avatar
Old Oct 6, 2005 | 11:59 AM
  #100
NismoMax80's Avatar
SuPeRmOd
So I emailed these guys that insisted 6th gens began in 05 so their FSTB fit 00-04. I sent them my cardomain page. Response:
Originally Posted by TuningPros.com
hi,
after look at the picture, i am pretty sure that this bar doesn't fit.
so do not bid on:
http://cgi.ebay.com/ebaymotors/ws/eB...3AAAQ%3AUS%3A1
Old Oct 6, 2005 | 02:05 PM
  #101
RHMax's Avatar
so do not bid on:
How sure is he, like 100% sure or more like 75% sure?
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
MaxStock
Aug 14, 2015 10:01 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
