external oil cooler?
Old Aug 7, 2005 | 05:53 PM
maxmale's Avatar
i am thinking of doing this, and was just wondering if it would be worth it. has anyone else done this yet. if so could you provide a write up as to how to go about it. i just want to keep the engine temp down.
Old Aug 7, 2005 | 06:01 PM
us024077's Avatar
won't do much for engine temperature, but will make the oil work at it's recommended viscosity, especially if you're driving in hot climates.
i had one on my old mgb (which notoriously ran hot in the summer). i can't imagine it would be worth the time effort or money on a new computer controlled engine.
Old Aug 7, 2005 | 06:27 PM
NismoMax80's Avatar
SuPeRmOd
where do you dirve that 5W-30 doesn't perform well enough? try Syn if you need assurance. would you remove the cooler in the winter?
Old Aug 7, 2005 | 06:28 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
MAXMALE,
what the hell are you doing to your car man, let us in on it.......
Old Aug 7, 2005 | 06:31 PM
SR20DEN's Avatar
VQ Wizard
The VQ35DE does not need an external oil cooler. It already has a heat exchanger at the oil filter. If you drop the oil operating temperature too much it won't properly lubricate the engine. Yes there is such a thing as the oil temperature being too low.
Although I am not saying that adding a cooler is a bad thing to do, it's just a waste of time and money for 99% of the circumstances.
Old Aug 8, 2005 | 12:04 AM
nick wolff's Avatar
sorry to change the subject a little...
but how about a trans cooler....? mines a POS from overheating. i like to drive... what can i say?
Old Aug 8, 2005 | 03:57 AM
E55AMG2's Avatar
Wat
They are worth it...esp if you live where its hot and you drive in stop and go
Old Aug 8, 2005 | 05:36 AM
maxmale's Avatar
i was also thinking of doing this also. would you just use the same cooler as if for the oil cooler?
Old Aug 8, 2005 | 04:14 PM
E55AMG2's Avatar
Wat
No, its a separate unit
Old Aug 8, 2005 | 04:21 PM
maxmale's Avatar
so you could not use the same part# for this. i do not mean use both at the same time. i was just saying i dont think you need to buy a tranny specific cooler.
Old Aug 8, 2005 | 09:18 PM
E55AMG2's Avatar
Wat
No, because an oil cooler is very small, whereas a transmission cooler is quite a bit larger. Were you to use an oil cooler for a tranny, the benefits would be negligible. Were you to use a tranny cooler for oil, you would overcool the oil and it would start to foam.
Old Aug 9, 2005 | 12:28 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Then your car would look like a Mad Dog going down the road...
tarun900
19
Dec 20, 2021 06:57 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
uttadms31
Sep 30, 2015 05:24 AM
