just got back form the dyno.
Old Aug 12, 2005 | 11:47 AM
maxmale's Avatar
just got back from the dyno.
this run here was in third gear. i wasn't to happy with the results so i had them do it in fourth as well. and here are the results from that run.
not really happy about this run either but it was also 95 freakin degree's when we did it and like 45% humidity. so maybe that affected performance. i hope. ENJOY
Old Aug 12, 2005 | 11:50 AM
maxmale's Avatar
and on a nother note guy offered me a nx wet kit 75 shot brand new still in box nitrous system for 300. should i take it?
Old Aug 12, 2005 | 11:51 AM
darrinps's Avatar
I believe that 4th gear is the right one (closest to 1.0).
Don't they have the ability to correct for ambient conditions?
As far as the results go...yes, with all of your "upgrades" that does seem a bit on the low side.
HOLD ON....just saw those wheels...that might explain some of it.
Old Aug 12, 2005 | 11:57 AM
Glude's Avatar
Your a/f is extremely rich in the higher RPMs, get your car to sr20den and im sure your numbers will be a lot higher.
Old Aug 12, 2005 | 12:07 PM
maxmale's Avatar
yup that settles it im getting the safc II tomorrow.
Old Aug 12, 2005 | 12:08 PM
maxmale's Avatar
my wheels are only +1 in size and at least the same weight as the stock if not less.
Old Aug 12, 2005 | 02:38 PM
JiuJitsuThug's Avatar
With the conditions you mentioned, the numbers don't look so bad...
Old Aug 12, 2005 | 02:43 PM
BEJAY1's Avatar
Conecarver
But the numbers are already SAE corrected.
Old Aug 12, 2005 | 02:53 PM
True - whoops.
Old Aug 12, 2005 | 04:47 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
i would, these kits go for 500+... go for it..
Old Aug 12, 2005 | 08:15 PM
ramberg's Avatar
GrandPa
I was going to put nitrous in my car but heard more bad stories than good ones. One thing I heard is that you shouldn't put more that a 50 shot in our cars. Think about it first. Warren
Old Aug 12, 2005 | 08:18 PM
ramberg's Avatar
GrandPa
[QUOTE=maxmale]
My friend here in Florida is taking me Tuesday to a shop to get a dyno. I quess my numbers will be about the same. Its hot as hell down here also. Warren
Old Aug 12, 2005 | 08:20 PM
SR20DEN's Avatar
VQ Wizard
The SAFC2 is a good choice but don't forget that the Emanage Ultimate is a better choice.
I also see that your dyno runs do not go to 6600.
However the 221whp looks pretty good.
Old Aug 12, 2005 | 08:37 PM
maxmale's Avatar
yea i guess he did stop a little short huh.
how much is the emanage ultimate running. im thinking im going to get the safcII for now and when they fix the whole rev limiter issue then probably switch.
what should my AFR be set at for best results?
Old Aug 12, 2005 | 08:48 PM
SR20DEN's Avatar
VQ Wizard
The best results are between 13.0 to 14.0 with 13.5 being a happy medium.
I think the EU is going to about $500 and the harness is about $100.
Old Aug 12, 2005 | 09:09 PM
E55AMG2's Avatar
Wat
Those are the correct stock #s
Old Aug 12, 2005 | 09:10 PM
E55AMG2's Avatar
Wat
Top Right Corner
CF: SAE Smoothing = 5
CF= Correction Factor
Smoothing = level of algorithm used to smooth out dips in the graph
With that being said, yes they are.
Old Aug 12, 2005 | 09:13 PM
E55AMG2's Avatar
Wat
Warren, which tuesday you gonna dyno in So. Fla? Id love to help yall out.
Old Aug 12, 2005 | 09:52 PM
Glude's Avatar
Wow that price is better then what I thought that would cost. Does it have better tuning capabilities than the safcII? Can it control timing? Thanks
Old Aug 13, 2005 | 12:00 AM
E55AMG2's Avatar
Wat
Yes (greddy > Apex'i all day long), and yes
Old Aug 15, 2005 | 01:09 PM
maxmale's Avatar
well, this is just an update. i grabbed the apex'i yesterday and am getting it installed on wed and will be dynoing again maybe that day. so we'll see if bringing my A/F up to 13/14 helps out.
Old Aug 18, 2005 | 06:49 AM
NmexMAX's Avatar
dot dot dot ...
Any news update on this?
Old Aug 18, 2005 | 07:07 AM
maxmale's Avatar
they weren't able to get to it yesterday so i am having to do it today. i will give an update on it this evening.
Old Aug 18, 2005 | 07:14 AM
NmexMAX's Avatar
dot dot dot ...
So, the SAFC is installed right now, just no dyno? How did the tach signal output deal go?
Old Aug 18, 2005 | 07:40 AM
maxmale's Avatar
the safc is being installed as we speak and i should have a new dyno on here this evening.
Old Aug 18, 2005 | 08:36 AM
andymax95
My question is, " Do all 6th gen max's run rich at higher rpms?" I thought since our computers are OB II that the car resyncs itself with the mods to recompensate the air/fuel levels to standard spec
Anyone with an answer
Also with an e-manage system, will it work even greater if you have the timing 2 degrees higher?
Old Aug 18, 2005 | 08:41 AM
NmexMAX's Avatar
dot dot dot ...
All cars are different ... PERIOD, meaning each car needs its own specific tune, especially A/F.
My car was rich, and leaned out with the mods I've added.
Old Aug 18, 2005 | 10:49 AM
Glude's Avatar
Looking forward to the dynos after tuning. keep us posted..
Old Aug 18, 2005 | 02:54 PM
maxmale's Avatar
ok, i got it hooked up but the guy said i have to wait to tune it untill i can get some dyno time which runs 120$ for the first hour and 80 each additional. does this sound right to you?
Old Aug 18, 2005 | 03:04 PM
NmexMAX's Avatar
dot dot dot ...
I pay $85/hour .. Will he be doing the tuning or you?
So, did they get the 04+ ECU/tach bugs worked out?
Old Aug 18, 2005 | 03:43 PM
Glude's Avatar
I was wondering this as well. I was browsing the altima forums and I noticed that someone mentioned this about the manual trans. but said it didnt apply to the autos. do they have this same problem?
Old Aug 18, 2005 | 04:49 PM
maxmale's Avatar
what ecu and tach problems. the only thing i am noticing is my cars tach is off by about 150-200 rpms.
Old Aug 18, 2005 | 05:51 PM
ramberg's Avatar
GrandPa
Is the safc II worth the price and how easy is it to install?
Old Aug 18, 2005 | 06:37 PM
maxmale's Avatar
i really cant answer that question yet. i havent tuned it yet. it is cool to look at but that alone isnt worth 400+ $. so i better see some freakin gains. plus i'm about to dump another 120 for an hour of tuning on the dynojet. i'll have more on this question when you drive back up here.
Old Aug 18, 2005 | 08:05 PM
Glude's Avatar
Its definately a better bang for your buck than the sp2 system is. That is, if your a/f is wack. Either way you should be able to get some gains from tuning.
Old Aug 18, 2005 | 08:44 PM
SR20DEN's Avatar
VQ Wizard
Wait, are you saying that you paid $400 for a Apexi SAFC-2 ? Or was that with installation?
Old Aug 18, 2005 | 08:51 PM
steven88's Avatar
Need A Light?
dont they run for like $260 shipped from ebay?
Old Aug 18, 2005 | 09:51 PM
Glude's Avatar
Yes they do. I didnt even catch that when reading it.
Old Aug 19, 2005 | 03:18 AM
maxmale's Avatar
that was with installation
Old Aug 19, 2005 | 01:50 PM
NmexMAX's Avatar
dot dot dot ...
So, did they get the 04+ ECU/tach bugs worked out? And how?
