Wiring Diagram for '05
Old 09-13-2005 | 11:12 AM
RHMax's Avatar
Newbie just Registered
Diagram for '05, but should be same for '04 and maybe '06. Source of diagram is good. However...
Attempt at your own risk.
Nissan Maxima 2005
12volts green (40A) + ignition harness
Starter black/red + ignition harness
Second Starter black/yellow + ignition harness
Ignition black/red + ignition harness
Accessory red + ignition harness
Second Accessory white/blue + ignition harness
Keysense black/red + ignition harness or
BCM, pin 37
Notes: The BCM (Body Control Module) is between the steering column and the fuse box.
Power Lock blue or pink/blue - driver door module in
door
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock red (double pulse) - driver door module in
door
Lock Motor gray 5wi BCM, pin 50
Unlock Motor green 5wi BCM, pin 44
Disarm Defeat green/yellow 5wi BCM, pin 51
Parking Lights+ red/blue + driver kick, harness to
rear
Parking Lights- N/A
Hazards green/red - BCM, pin 29
Turn Signal(L) green/black + BCM, pin 45
Turn Signal(R) green/yellow + BCM, pin 46
Headlight blue (L), red/yellow (R) + IPDM E/R, pins 30 and
20
Notes: The IPDM E/R (Intelligent Power Distribution Module Engine Room) is behind the
passenger side headlight. All the wires are in a gray 16 pin plug.
Reverse Light green/white + driver kick, harness to
rear
Door Trigger see notes - BCM
Notes: The LF door is lt. blue in pin 62, the RF door is brown/white in pin 12, the LR door is
red/black in pin 63, and the RR door is blue/red in pin 13. Use all four wires and diode isolate each.
Dome Supervision red - BCM, pin 48
Trunk/Hatch Pin purple/white - BCM, pin 57
Hood Pin N/A
Trunk/Hatch Release blue or blue/white - BCM, pin 30
Notes: The BCM (Body Control Module) is between the steering column and the fuse box. The fuel
door release is green in the driver kick, in the harness to the rear. It is a high current negative wire.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock single pulse power
unlock wire
Tachometer NOT red or black ac any ignition coil or fuel
injector
Wait to start N/A
Speed Sense green or brown 8P Unified Meter and A/C
Amp, pin 26
Notes: The Unified Meter and A/C Amp is the first module below the display in the dash.
Brake Wire red/green + brake pedal switch
Parking Brake pink/black - parking brake switch
Horn Trigger green/white - horn switch
Wipers blue (L), blue/black (H) + IPDM E/R, pins 21 and
31
LF Window up/dn see notes
Notes: Extended triggers on the lock/unlock wires will roll the windows up/down. Use validity
channels to control.
RF Window up/dn see LF window up/dn
notes
LR Window up/dn see LF window up/dn
notes
RR Window up/dn see LF window up/dn
notes
Sun Roof open/close motor part of module
Sun Roof Limit/close N/A
Memory Seat 1 blue/white - ADP Control Unit, pin 9
Notes: The ADP (Automatic Drive Positioner) control unit is the second module below the display in
the dash.
Memory Seat 2 purple - ADP Control Unit, pin
25
the dash.
Memory Seat 3 N/A
Radio 12v yellow + radio harness
Radio Ground (chassis)
Radio Ignition purple + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/white + radio harness
Power Antenna green/white + radio harness
LF Speaker +/- white - black +,- radio harness
Notes: The BOSE speaker amp is under the rear deck. The speaker wiring at the amplifier is: LF
blue/white - blue/black, RF white/black - green/black, LR green/yellow - blue/yellow, and RR blue -
red.
RF Speaker +/- yellow - brown +,- radio harness
LR Speaker +/- green/yellow -
black/yellow
+,- radio harness
RR Speaker +/- blue - red +,- radio harness
Immobilizer Bypass
Module:
Required: Yes Type: Transponder Part #: 556UW
Notes: Standard on all models.
It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Old 09-13-2005 | 03:50 PM
MAXDOUT04's Avatar
* THIS SPACE FOR RENT *
If this holds true make it a sticky?......
Old 09-13-2005 | 03:53 PM
kpr10is's Avatar
All the remote start/alarm related wiring is already stickied in the Audio forum, just fyi.
Old 09-13-2005 | 08:23 PM
rabenoja's Avatar
Hey, here's another tip to add to that wiring diagram up top. When doing remote start use the factory rearm wire from the remote start to trigger a relay to pulse the door trigger wire. This will shut off your lights if you have it on auto mode. You also have must wire the relay to split the door trigger wire if you have an alarm/remote start combo.
Old 09-14-2005 | 12:23 AM
ramberg's Avatar
GrandPa
Try this and check this out at nycmaximas http://forums.nycmaximas.org/showthread.php?t=4911
Old 09-14-2005 | 08:08 PM
rentalman's Avatar
Is there no place to get a usable tach signal INSIDE the cabin?
Thanks,
Brad
Old 01-17-2006 | 12:42 AM
jsmithsole's Avatar
*moderator*
Found the link for this (a bit easier to read....)
Old 01-17-2006 | 05:59 AM
-Sin-'s Avatar
try this worked for me... http://www.carsound.com/UBB/ultimate...=002070#000000, defroster is also on the BCM can't remember which but I wrote about it before...
trsandrew
04-08-2016 07:45 PM
doctorpullit
03-29-2016 12:08 PM
trsandrew
10-25-2015 03:47 PM
Kyle Lee Cleveland
09-28-2015 10:03 AM
Quick Reply: Wiring Diagram for '05
