Light grinding from engine
Old Oct 12, 2005 | 07:21 AM
dopestar129's Avatar
Can anyone here tell me if they've had this problem? At exactly 2500 rpm my engine is making a light grinding type of noise. It's only at 2500 rpm when I have my foot on the accelerator. Anyone know what this might be? Thanks for any help. By the way, I have an automatic SE.
Old Oct 12, 2005 | 08:12 AM
ramberg's Avatar
GrandPa
I don't know what is is but I would go directly to the dealer. It will be covered under warranty.
Old Oct 12, 2005 | 11:07 AM
I'm definitely taking it to the dealer this weekend. Everyone I've talked to can't really think of what it could be. I guess I'll see soon. I think I'll also have them check out the rattling my sunroof makes ever since they fixed a drainage problem I had. Bastards.
Old Oct 12, 2005 | 11:13 AM
masama's Avatar
Grinding noise? Sounds scary. Better be at dealers as soon as you can.
Old Oct 12, 2005 | 01:59 PM
scavynger's Avatar
I had a similiar noise. Mine was most noticable right at 3k rpms, although i heard it before and after that. Do you hear it while you are in neutral or park?
MIne turned out to be a broken air intake valve, or soemthing like that. Dealer ordered the part - should be coming in soon.
Old Oct 13, 2005 | 02:48 PM
I've so far heard it while driving and keeping it steady at 2500rpm. I'd assume it would do the same thing in Neutral or Park, but I have yet to check that out. Just talked to the dealer and she's going in on Saturday.
Old Oct 13, 2005 | 05:07 PM
logik05se's Avatar
could be one of the heat shields under the car, usually over the cats....when they get loose they make a grinding noise.
Old Oct 13, 2005 | 07:32 PM
kenttz's Avatar
I hope it isnt detonation.
Old Oct 13, 2005 | 07:35 PM
NismoMax80's Avatar
SuPeRmOd
please also check while in manual mode. curious if it's present in each gear. Any news from dealer yet?
Old Oct 13, 2005 | 07:50 PM
pae1215's Avatar
The TSB link is 2004-2005 NISSAN MAXIMA AND QUEST; EXHAUST RATTLE / BUZZING NOISE PRESENT DURING ACCELERATION
I had the same problem 3 months ago!
looking at the tsb
now looking under my car...i was able to see the cracks
When idling it would not do that or when coasting would not do that either. but as soon as you tap on the gas at about 2K-3K it starts rattling. Its a 8-10 piece that the stealership will replace for free. I did it myself, was a ***** to get under the car without a lift. so have them replace it.
Old Oct 13, 2005 | 07:53 PM
kenttz's Avatar
Very interesting good info, I am going to check my max aswell.
Old Oct 13, 2005 | 08:40 PM
tubells's Avatar
I hear a grinding noise.. or some kind of whirring (tranny?) when I accelerate suddenly..
this started recently... c'ant get it "on demand" yet, that I can take it to the dealer and show..
Old Oct 14, 2005 | 12:09 PM
jasonjm's Avatar
I had grinding. Soon after tranny blew, TQconv wouldn't lock. It was replaced. If the noise is something that always happens go to the dealership asap and have them diagnose it.
Old Oct 17, 2005 | 10:44 AM
It did end up being that exhaust bracket. Apparently it was cracking and they said a number of Maximas were brought in with the same problem.
Old Oct 17, 2005 | 09:18 PM
pae1215's Avatar
but the thing that sucks is that they are replacing it with the same piece. eventually that will break again.
Old Oct 19, 2005 | 04:13 PM
wsu's Avatar
wsu
me too
I had the same problem. It was pretty annoying but the dealership took car of it promptly.
Old Oct 19, 2005 | 04:18 PM
wsu's Avatar
wsu
Uh Oh...
I hope that what your are saying is not the case. It wouldn't make sense for Nissan to replace a defective part with another defective part. Doing so would just make for more service costs that might have to be absorbed by Nissan. Do we know if it was the bracket per se (metallurgy, design, or whatever) that was the problem, or was it that the original installation was not done correctly, which led to detachment from the mounting points, and then vibration/breakage.
Matt93SE
May 24, 2019 02:58 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
carlosvq30
Aug 17, 2015 11:32 AM
sc10692
Aug 9, 2015 09:37 AM
