where is Fog Light FUSE?
Old Nov 1, 2005 | 03:22 PM
minsbang's Avatar
It's in the black box next to the windshield washer fluid tube, right? It's just ONE fuse, correct?
The micro h3 came with two 15v fuses, but the stock already uses 15v, no?
Old Nov 1, 2005 | 03:25 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
not sure, but you should be fine if they turned on and all, that fuse woul've blown as soon as you turned them on if they took too much power over the stock fuse..
Old Nov 1, 2005 | 06:12 PM
zdaddyrob's Avatar
There's one Fog Lamp fuse and it's located in the IPDM (power distribution) box adjacent to the coolant reservoir. It is fuse# 43 and it's a 15A.
Old Nov 1, 2005 | 08:18 PM
minsbang's Avatar
The direction says to replace the one provided, which has the # 15 on it.
Old Nov 1, 2005 | 09:08 PM
MAXIMA-GHOST's Avatar
hey i have the H3 mini's too (Helios) 6000K Kit.. Where are you putting the ballasts and igniters..?? Thanks
Old Nov 2, 2005 | 05:53 AM
minsbang's Avatar
I just placed them where ever they feel tight and secure. I didn't use the double sided tape or the metal plates. here are two pics.:
I hope this helps you
Old Aug 6, 2012 | 09:40 PM
harley2005's Avatar
Can someone post a fuse diagram for a 2005 maxima, the IPDM cover doesn't show fuse numbers .....
Old Aug 7, 2012 | 09:06 PM
DAlastDON's Avatar
Old Aug 8, 2012 | 08:10 AM
twentyeggs's Avatar
your fog light fuze is fine, both of your fog lights are burnt out.
maybe? it happened to me.... 4 times... my fog lights dont last more than a few months before they blow... very stupid, gunna replace them with HIDS if someone could point me to a plug and play brand. if not, ill point myself when i have the ambition.
Old Aug 11, 2012 | 12:20 AM
DAlastDON's Avatar
I think the spammers heard you.
http://forums.maxima.org/general-max...-hid-kits.html
Old Aug 27, 2012 | 12:51 PM
deece01's Avatar
ipdm
i noticed on my ipdm box it has a diagram showing the layout as well as which fuse controls what. i've located the fuses i need to check out (it's not my bulbs, i checked), but i'm wondering if there's anyway to pull the ipdm out a little bit more so i can get in there with some pliers. i'm new to the maxima and not sure if how the ipdm's connected, or if there's a way i can just pull it out a bit so i have some working space.
any suggestions are appreciated...and i apologize ahead of time if there's another thread for this, but seeing as to how this relates to my fogs i think it's appropriate
thanks everyone.
The Frye
Sep 2, 2021 11:03 AM
Jamie Bowen
Sep 6, 2015 09:59 PM
pktaske
Sep 4, 2015 08:40 AM
mikebla
Sep 3, 2015 05:37 PM
