Help With Maintanance settings on Computer
Old Nov 18, 2005 | 08:31 AM
2k2MaxiBlue's Avatar
when you press the button, oil change and tire rotation does not go on
i have no clue how, but if i press it once in a while, it will go on, but then shuts off. i tried resetting it as well, and cannot. for example. my oil change was set at 7500 miles. once it hit that, the computer blinks, so i move the **** to the left to set it at 0, then i hold the maintanance button to try to reset it, nothing happens. any one have such an experience
Old Nov 18, 2005 | 09:53 AM
NismoMax80's Avatar
SuPeRmOd
make sure you're in park to change any settings. u will see it flash to change interval. holding it should reset it. i'd have to search old post to be sure.
Old Nov 18, 2005 | 11:28 AM
ramberg's Avatar
GrandPa
Did you read your manual to make sure you are doing it right?
Old Nov 18, 2005 | 03:25 PM
boone's Avatar
You gon' pay what you owe
It sounds like you are doing the opposite of what you want to do. If you want the log to stop nagging you, then you don't want to set it to zero or else it will nag you all the time. Instead of changing the interval to zero, just reset it.
Old Nov 21, 2005 | 10:33 AM
i finally got the oil change to totally reset, but i cannot add miles, where i want to remind me to change the oil, (the top #) the bottom is actual miles drive, correct?
Old Nov 21, 2005 | 10:35 AM
NismoMax80's Avatar
SuPeRmOd
like i said (and stated in the manual) you must be in PARK. once you select oil or rotation, brackets will flash around your interval. go left or right to change. yes, bottom is how many miles since you last reset them.
Old Nov 21, 2005 | 10:51 AM
i am doing it in park, i used the get the brackets prior to the reset, now i do not. when i had them before it would only go to 0 or 7500 when i moved it left or right
Old Nov 21, 2005 | 11:20 AM
Factory36's Avatar
I fought with this for a while on mine. I finally figured out that the bottom number is the running total of miles before the next service. The top number is when you want the warning to alert you of the maintenance.
So if you want the system to warn you in 7500 miles that it is time to change your oil, set the top number to 7500 and make sure you have cleared the bottom number. The system will then track your miles driven and warn you when you get to the preset interval.
It functions independently of the odometer. Hope this helps.
Old Nov 21, 2005 | 11:23 AM
the problem was i couldnt change the top # especially after i reset the bottom
Old Nov 21, 2005 | 11:52 AM
Factory36's Avatar
Sorry, I don't think I had any problems there. I had 2 or three options, something like 3000, 5000 and 7500 or just 5000 and 7500.
aw11power
Oct 10, 2021 04:57 AM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
