Cattman Springs!
Old Nov 21, 2005 | 06:41 PM
VQMAX05's Avatar
Cattman Springs!
On 11-22-05 I will have my new Cattman Springs and RSB installed in the MAx. I will post pics of the car with the the new staggred wheels and the cattman springs. I had Eibach before bad luck.... noises! so lets see how the Cattman ones do.
WILL REPORT Difference right away.
JOn
MI SIG HAS EIBACH AND CHOPPED STOCK WHEELS... NEW WHEELS AND NEW MODS UP SOON!!
PS. Mark aka Deusesmax Thanks for Brian Catts info.. he is a great guy. and thanks you for all the guidance.
Old Nov 21, 2005 | 06:46 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
I tend to like it better when someone actual does something to his ride first than posts it verse bait and wait...
Old Nov 22, 2005 | 05:25 PM
VQMAX05's Avatar
Well, I have an update for you guys....
Springs are in and it is lowered....but then here is the funny thing....the shop installed the Cattman RSB backwards in the car..... so back it goes tomorrow to get corrected.... RIdes like crap right now... Should be much better tomorrow....
But loving the drop nice look to it...
Jon
Will update again tomorrow.
Old Nov 22, 2005 | 06:15 PM
MObruin's Avatar
Jon
I will be getting my springs and RSB installed soon and this brings up a good question......
If the shop installs your RSB backwards, how would you know?? Just because it rides bad, is there any other way to tell?
I want to make sure its done right the first time, so do I just tell the installer to make sure its not backwards??
-MO-
Old Nov 22, 2005 | 07:08 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
-MO-
look at how the oem one is before you take it off, they are both similar..
Old Nov 22, 2005 | 07:53 PM
gec
Ok its 11-22-05 almost 11-23-05 so hit us with the pics mang....
Old Nov 22, 2005 | 08:38 PM
RHMax's Avatar
Newbie just Registered
Jon
Make sure the bar and your suspension damaged. If it's in backward, it would ride on the control arms.
Old Nov 23, 2005 | 06:28 AM
VQMAX05's Avatar
That is exactly what happened........ NO DAMAGE thankfully!!! drove slow and easy over bumps.
Should be done by noon or so... will update then.
Jon
Old Nov 23, 2005 | 06:49 AM
gtr_rider's Avatar
192.168.1.1
pictures would be nice
Old Nov 23, 2005 | 08:26 AM
Glude's Avatar
yes they would. I wanna see a comparison pic. In others it appears the progress sit lower in the front, if thats the case then I might just go that route instead of the Teins.
Old Nov 23, 2005 | 10:32 AM
VQMAX05's Avatar
I just picked up the car..... WoW!!!! so much better than the Eibach's, they are nice and stiff without being harsh... and the RSB!!!! is amazing.. This is a must do combo.... They had my car parked right next to a 04 Max with 19's and Eibachs mine was just as low. Pics are coming very soon!!!
Car is dirty. I will post on Cardomain.... dont know how to post pics here.
thanks
Jon
Old Nov 23, 2005 | 10:47 AM
KUBLKMAX's Avatar
ok this may seem very trivial to some but where can one get these springs and rsb? What is the cost of them compared to others out there? Which springs are gonna give the best ride meaning not as harsh I hate that bouncing feeling.
Old Nov 23, 2005 | 11:05 AM
gtr_rider's Avatar
192.168.1.1
thanks
Jon
How about you go back and ask that owner if he is on SFMG?
Old Nov 23, 2005 | 10:13 PM
kamski's Avatar
.org extraordinaire
Hahahah
www.watsonsglen.com/Kam/Maxima/loweringkit
ENJOY!!!
Who has got allignment done on their car afterwards? Even tought the car drives straight after the allignment the steering wheel seems crooked to me, its only a .5 degree or so, but when i straighten the steerign wheel it goes left, mostly highway.
In city if i straighten the wheel its not as noticable.
Kam
Old Nov 23, 2005 | 10:30 PM
RHMax's Avatar
ENJOY!!!
Kam
I had the alignment checked after installed. It didn't need any adjustment. Enjoy is right.
Old Dec 5, 2005 | 08:31 AM
ivanko's Avatar
what about camber adjustment after lowering
Old Dec 5, 2005 | 08:44 AM
RHMax's Avatar
If you want to adjust camber, you need camber kit. I know the front isn't adjustable, but I read that the rear could be. W/ hard driving, won't you want a slightly negative cambers?
Old Dec 5, 2005 | 09:00 AM
DeusExMaxima's Avatar
My camber was checked after installing the springs and I believe it is now 1-1.5 degrees negative which is very good for street driving.
Old Dec 5, 2005 | 09:26 AM
ivanko's Avatar
yah but ur tires will wear unevenly if the camber is not adjusted correctly
i had a 95 maxima before the 2004 and when i lowere that one i was told the same thing about u want it to be slightly negative but the tires wore out on the inside fairly quickly then i did a camber adjustment and the car was fine after that for the almost 40000 miles i drove it before getting the 04
Old Dec 5, 2005 | 09:36 AM
Well typically, if u make mods like this, you're going to be engaging in some high performance driving, which increases wear on the outside. As u drive regularly, it increases wear on the inside, which balances it out. I dont think 1 deg negative is going to wear out tires that much, and in fact, may even be within OEM tolerances.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
