Converting a Non-Navigation Maxima to Stock Navigation
Old Dec 20, 2005 | 10:41 AM
Killah Kane's Avatar
Does anyone know anything about this? I have a 2004 max without navigation, however I really want to convert it to the stock navigation system. Does anyone know if this is possible? Has anyone or anyone you know done this? Yes I know I can always add a aftermarket system that will probably be even better than stock, but I want to know if the stock option can be added or not...thanks
Old Dec 20, 2005 | 11:03 AM
us024077's Avatar
need to check past posts. this has been discussed several times.
Old Dec 20, 2005 | 11:28 AM
koenigsegg671
I have all the stock navigation pieces for a 2004 if you are interested, the whole center console essentially
Old Dec 20, 2005 | 12:04 PM
I have checked previous posts and have posted as well and I have never gotten an answer as to if it can be done or if anyone has done it. Nobody posted any details regarding this and I checked all the posts. If you see a post, please link it here because I can't find it
Old Dec 20, 2005 | 12:07 PM
viguera's Avatar
The consensus seems to be that it's so expensive as to be prohibitive. You need a new screen, the drive, the new contol unit and buttons, plus the antenna and associated wiring. I'm not sure if there's a space in the dash under the security LED on non-nav cars for the antenna, but I'm guessing that there is... if not, then it's re-work the dash or mount the antenna elsewhere.
Regardless, if you can get the parts, then try it and see if it works... I don't think anybody's decided to spend that much money just to get OEM navigation, when they can get something equally as good for much cheaper, or spend the same amount of money and get something like the AVIC units that do navi plus more.
Good luck...
Old Dec 20, 2005 | 02:15 PM
us024077's Avatar
you'll also need a new windshield...the nav one is different than the non-nav one. go figure!
tcb_02_max
Sep 11, 2015 12:23 PM
Maxilano
Aug 31, 2015 07:33 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
yat70458
Aug 3, 2015 01:16 PM
