Suspension Upgrades....Scary moment..
Old Jan 3, 2006 | 10:42 PM
  #41
RHMax's Avatar
Newbie just Registered
Originally Posted by CCS2k1Max
And people here wonder why the bimmer guys call us ricers...
Yeah, but ricers come in all shapes colors, sizes, and makes; Bimmers included.
Old Jan 4, 2006 | 06:23 AM
  #42
jasonjm's Avatar
The keyword here is 'Jounce'. You'll hear it a lot from techs/racers/pit pads/ etc...
If you do a search on google for suspension jounce, you should get some very detailed explanations/solutions than other words. This should help you to better understand the situation from a technical perspective.
(i.e. one search result: http://www.monroe.com/tech_support/t...systemfund.asp)
Old Jan 4, 2006 | 06:32 AM
  #43
maxdizzle1's Avatar
That's surprising with your new wheels and tires that you had that happen. I've got the Eibach drop, Stillen RSB and Stillen front strut bar with 20's and I've taken several curves at crazy speeds and never had that happen. The only thing I have ever worried about is rolling the tires over and scratching the wheels. I think rubber can be a factor too and like Deus said, the front strut bar. I had the Toyo T1-S tires for about a year or so and after they got worn down, they began to really slip off the line. I could barely take off from a stop without spinning. Now I've got the Toyo TR-1's and the grip is unreal, major difference. Good luck and consider the strut bar.... PEACE
Old Jan 4, 2006 | 10:27 AM
  #44
d00df00d's Avatar
Old enuf to pick his own gears
....Huh?? Jounce is just another word for compression. How is that the key word?
Old Jan 4, 2006 | 10:34 AM
  #45
Iron Scimitar's Avatar
Tha Snatcher
Originally Posted by NYPD-Arnold
The problem here is the VQMax is a fool for taking an exit ramp going 70MPH. The other problem is that he has a RSB and expected his vehicle to stay put at that speed? The point of the RSB is to increase oversteer, which was done. Your struts didn't hinder much, if anything, at all. Struts decrease bounce, not body roll. You need to start tying down the car now. You need a strut bar and a front tower brace to match the oversteer you've increased by adding an RSB.
bingo.....
6th gen around and off ramp @ 70mph = pwnage
Old Jan 4, 2006 | 10:48 AM
  #46
bluemaxx's Avatar
Moderator GT-R
Jounce is another word for moving up and down. In this case it sounds like a lack of jounce might be key to the problem. A stock suspension with properly inflated RSAs probably would have carved up that ramp without a problem...
Old Jan 4, 2006 | 10:58 AM
  #47
d00df00d's Avatar
Alright guys, ease up a little. A 6th gen is no handling beast, but with some mods it should easily be able to take a fast ramp. It's long and wide, so if it's low enough, stiffly sprung, and riding on good, fat tires, it should be very stable and capable of some serious lateral grip.
I should know... all my 4th gen has are coilovers and a FSTB, and even on my 205-section tires it's totally planted on highway ramps at speeds that have my brother's stock Integra LS nearly lifting a wheel. That's the Maxima's strong point handling-wise: stability and grip for relatively gradual corners -- like highway ramps.
Of course, as I should also know, the car still won't be very tossable (my brother's stock 'Teg slowly runs away from me in the super-twisties). Plus, whether you agree with taking ramps at 70 regardless of your car's abilities is a matter of opinion. But it's not like he's hit some kind of brick wall with his car's abilities that it's foolish to try to penetrate.
Besides, it seems his car's abilities are almost there anyway. In all fairness, it was only near the end that he started to lose it, and apparently it wasn't that bad... otherwise we'd be hearing about a colossal tail slide, a spin-out, or a wreck.
Old Jan 4, 2006 | 10:59 AM
  #48
RHMax's Avatar
So VQ's combo was too stiff to get good traction on that ramp? Or could be the tires need a little more scuffing, or less air.
Old Jan 4, 2006 | 11:28 AM
  #49
bluemaxx's Avatar
Moderator GT-R
My guess is too stiff and noncompliant for the road surface.
Only one of us has actually seen the ramp in question but... my 6th gen on stock suspension and Michelin Pilots is not afraid to take most on/off ramps significantly faster than the posted speed. I don't think mine is a factory freak.
Old Jan 4, 2006 | 11:31 AM
  #50
RHMax's Avatar
No, you got Pilots...
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
