Removing rear deck?
Old Feb 8, 2006 | 06:22 PM
imnotoriousjoe's Avatar
Removing rear deck?
Does anyone know how to do it?
I was thinkin that the screws behind the rear seats (when you pull the backseat foward) remove it but I cant try it because my car is in the shop
thanx
Old Feb 8, 2006 | 08:31 PM
AscendantMax's Avatar
yeah, curious as well. looks like those bolts are holding down that piece behind the seats.
Old Feb 8, 2006 | 10:42 PM
kamski's Avatar
.org extraordinaire
me 2
any one done this yet?
Kam
Old Feb 9, 2006 | 08:39 AM
myer84's Avatar
I tried doing the same. U have to remove the screws and remove the plastic cover. From there u just pop the deck up. The only problem is that u have to remove the seatbelt harness in order to complety remove the reardeck. Its kind of confusing and the seats make it more dificult to work around. If u know how to remove the rear seats go for it. I think it will be easier for u to work with the rear deck.
Old Feb 9, 2006 | 11:35 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
yea I did it also.... the seats, plastic, seatbelts all have to be removed. even to fully take out the carpet in the trunk you have to go through this..
Old Feb 9, 2006 | 12:13 PM
well I dont want the whole deck to come up just the top part
So I just remove the screws and pop it up?
Old Feb 9, 2006 | 12:16 PM
Tek-Niq's Avatar
I know what you ment... I forget now, but the cover might be held down by some of this, thats why you might have to remove them.
the actual rear deck can't come off, is welded to the top of the wheel wells. kinda acts like a rear strut bar..
Old Feb 9, 2006 | 05:33 PM
the stock subs are top mounted correct?
Old Feb 9, 2006 | 07:23 PM
jsmithsole's Avatar
*moderator*
Not looking forward to this one, my new box unleashed a whole new gang of rattles!!!
Old Feb 9, 2006 | 07:42 PM
boone's Avatar
You gon' pay what you owe
First you need to remove the panels covering the C-pillars. Be very careful when doing this because one of the friction fittings (the orange one) can be a bear to get loose. I recommend getting a panel popper tool. Autozone has them for a few bucks. Second, you need to fold your rear seats down and take out the bolts holding the frame for the rear seat in place. Four of the bolts are located behind the panels covering the folding seat latches. Third, remove the rear door sills. These are also held down by friction fittings. Once the sills are out, you can pull the rear seat frame forward. Last, you can slide your hand under the rear deck and carefully start popping the friction fittings holding it loose. One word of warning, pay close attention to the locations of the friction fittings because when you go to put the deck back together, you have to make sure all of them are seated back down or your deck will rattle.
Old Feb 9, 2006 | 08:05 PM
9Nails's Avatar
Mine appear to be. See my other thread for pic's:
http://forums.maxima.org/showpost.ph...98&postcount=4
Old Jun 20, 2010 | 03:06 PM
crimsonandbrown's Avatar
Same Problems
I have an 06 max sl and I have a center console in the backseat so my seats do not fold down. I want to know how to remove the backseats so I can get to the rear deck?
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
