Pulley and Performance Mods questions..
Old Feb 24, 2006 | 12:40 AM
05MAXIJJ's Avatar
I an intrested in buying a racing pulley but would like to know the difference between the Unorthodox Racing Ultra Sc Street Charger Pulley and Unorthodox Racing - Ultra S Street Crank Pulley ??
1)Whats the difference between the S and Sc Pulley?
2)What are other performance mods i should do in which order?
3)Would the intake and pulley show some result?
4)I ordered a injen CAI and about to order a Racing pulley. Is that a OK" combo?
Sorry for so much questions..Decided to do some modss.
Thank you..
Old Feb 24, 2006 | 05:22 AM
greg hazlett's Avatar
I would like to know also...
I have the Injen CAI, CE mid pipe and just ordered a cat back system from ebay, that seems to be it on mod options although an ECU mod is in the works and I would recommend that last so that the tune will take advantage of all the other mods. Headers are under construction from Cattman, results TBD.
Old Feb 24, 2006 | 06:22 AM
maxmale's Avatar
i believe the difference is this. one is an underdrive pulley which means it is a different size than stock and therefor underdrives the accessorys, and the other i believe is stock size, both are light weight. i could be missing something here though.
my first mods for an SL would be suspension. performance wise would be exhaust/intake,
Old Feb 24, 2006 | 04:29 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
this is the next thing I'm going to dyno, I just bought it from CE, it should be here soon...
Old Feb 24, 2006 | 05:38 PM
The pulley or the mid pipe?
Old Feb 24, 2006 | 06:52 PM
maximob's Avatar
A light weight pully would be cool if the diameter stayed the same. I noticed the AC only cools good in the summer when the RPM's are alittle higher.
I curious about the ECM options. TEK is getting his chip rewritten for his mode, and others are using SAFC tuners. Other cars have the ability to connect a laptop and tune on the fly. Is this possible with the SAFC tuners? I would like to be able toswitch between fuel saving and performance.
Old Feb 24, 2006 | 11:20 PM
ramberg's Avatar
GrandPa
[QUOTE=05MAXIJJ]I an intrested in buying a racing pulley but would like to know the difference between the Unorthodox Racing Ultra Sc Street Charger Pulley and Unorthodox Racing - Ultra S Street Crank Pulley ??
First of all how many miles to you have on your car? You put in any pulley and something happens to the engine and the pully caused it. Say good bye to the warranty. Now if you don't care about that than here it goes. I would hold off on the pully for a while.
I have the URP, Injen CAI, CE Y-Pipe and the Greddy SP-2 Cat-back system.
Some members have the cattman cat-back system. There are alot of different companies out there for the 6th gen.
So check out the stickies which have good information also there are alot of threads on the questions that you are asking. Just so a search or run thru the pages you will find all the answers.
Check this out. I hope it helps.
http://forums.maxima.org/showthread.php?t=413817
Old Feb 25, 2006 | 08:05 AM
Tek-Niq's Avatar
I'm doing the pulley, I wanna get as much HP with the stock exaust first.
Old Feb 25, 2006 | 09:45 AM
maxmale's Avatar
the only way i would get a pulley is if it came in a set. i don't want to underdrive my accesarys, i would however get a light weight fly wheel. hey SR20den, who much for the ssim.
Old Feb 25, 2006 | 11:27 AM
CopperMax's Avatar
does UR make a pulley kit for the maxima's...like they do the 350z??
Old Feb 27, 2006 | 06:50 PM
Mightymousehhd4's Avatar
ive looked around for the pulley kit for the 6th gen but couldnt find it......dont think it is out yet.......but i just put my UR Pulley on today and i can def. feel the different........the tach jumps from 2500 to 5000 with no hesitation!!!
Old Mar 1, 2006 | 10:07 PM
madmik's Avatar
Haven't installed my pulley yet. Got spooked by threads on leaks through the key or rear seal.
Old Mar 1, 2006 | 10:25 PM
DeusExMaxima's Avatar
I havent installed mine either, but its just a matter of getting that darn crank bolt off.
Old Mar 2, 2006 | 09:54 AM
ramberg's Avatar
GrandPa
You still can't take that damn bolt off? Bring your car to NY. We will take care of it for you.
Old Mar 2, 2006 | 09:56 AM
ramberg's Avatar
GrandPa
I know myself and chermax have can our pulley's on for over a year and have had no problems. If the pulley is installed correctly you should be OK. If you have under 36,000 miles on your don't do it yet because of the warranty. Just in case somrthink happens.
Good luck
Warren
Old Mar 2, 2006 | 10:08 AM
My car only has 1600 miles on it and it has the CAI, mid pipe and cat back, what's one more mod......LOL
Old Mar 2, 2006 | 10:13 AM
ramberg's Avatar
GrandPa
Go for it and than install the juice.
Old Mar 2, 2006 | 12:17 PM
Uhhhhhhh.....
I was thinking the secret mod Tek had and then maybe the ECU work.....
Old Mar 2, 2006 | 06:32 PM
Tek-Niq's Avatar
Uhhhhhhh.....
people advertized that mod for the our maxima, but it don't fit our car at all. sucks!
it was a plenum spacer, 10hp at the wheels, but thats off the list..
back to the drawing board... looking into cams and pistons..
Old Mar 2, 2006 | 06:36 PM
Plenum spacer, not a TB spacer, right? I have yet to see a TB sapcer be more than a paper weight. ANy updates on your ECU saga?
Old Mar 2, 2006 | 06:47 PM
Tek-Niq's Avatar
yea a plenum spacer....
ecu update will be on wednesday..
Old Mar 2, 2006 | 10:38 PM
ramberg's Avatar
GrandPa
Would the one for the G35 work?
http://www.nipponpower.com/product.phtml?p=781
Old Mar 3, 2006 | 03:28 AM
Tek-Niq's Avatar
no, we don't have an intake that looks anything like what that goes on, you have to look at a Z's intake to know...
plus thats the part they sent me, as soon as I seen that I was like hell no!
Mahmuth
Aug 16, 2024 08:23 PM
Apr 16, 2020 05:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
