LED puddle lights
Old Mar 23, 2006 | 08:05 PM
VQMAX05's Avatar
LED puddle lights
Guys,
I am planning on getting a little creative this weekend.
I am planing of putting 6 (4 LED light pods) under each side of the car,
In white that light up when you open the door. Should be a nice touch. I saw that on a MB E55 AMG the other day. Real sweet touch. Now my question is, what do u guys think And where do I find the place to wire these lights into. I want to hook it up to the dome light(interior light) so the LED's dim out as do the lights inside. I have these LED pods on my Harley around the motor. Looks sweet. Please can someone chime in and tell me the wiring proces for this.
VQ
Old Mar 23, 2006 | 08:55 PM
jsmithsole's Avatar
*moderator*
Not sure how to get the wires inside the car but once you do just tap into the lights that light up the footwells. When I disarm my alarm these come on (I think the stock keyfob does this as well, can't remember) What lights are you going to use again? Seems like 6 pods would make the light kinda spotty why don't you get one of these to spread the light evenly? I used these in my trunk:
Old Mar 23, 2006 | 10:08 PM
RideTuner's Avatar
I tried something similar but thought about putting it under the side mirrors. I tried tapping into the door light (bottom of the door on the inside), but it didn't work. After splicing into the door light all the door lights stay on even after I lock the doors. I waited but they never went off. After I removed the wires back to original the lights go off after I lock the doors. Anybody know why? I probably did something stupid but I can't figure it out.
I tried it with these:
Old Mar 23, 2006 | 11:27 PM
jsmithsole's Avatar
*moderator*
That is odd, I replace my footwell lights with and LED light board and they work fine, maybe try to tap in there. And that bulb looks like a strobe(actually your link for the pic says strobe in it), not just an LED?? Maybe that could be a problem? I used a similar LED bar as my cornering lights for a while, weren't as bright as I had hoped though (and one fell off somewhere due to my rigged temporary install!!)
Old Mar 24, 2006 | 07:44 AM
shadowfox777's Avatar
jsmithsole,
I was thinking of also installing that flexible leb tube light in the trunk. I was wondering how hard it is to install? Did you just tap into the interior trunk light? Also how bright it is and how many of those flex led tubes did you use? I was just planning on just using one tube.
Old Mar 24, 2006 | 11:13 AM
jsmithsole's Avatar
*moderator*
Originally Posted by shadowfox777
jsmithsole,
I just tapped into the stock light, real easy. It's nice and bright!
I just uses one of the 36" ones in white.
Old Mar 24, 2006 | 11:43 AM
05MaXiMaMenG's Avatar
where did you get those lights and how much?
Old Mar 24, 2006 | 11:52 AM
jsmithsole's Avatar
*moderator*
http://autolumination.com/tubes.htm
Scroll down to the bottom. (I also added the 3 led pods which is what you see in the pic) The LED tube/strip runs along the box and is hidden, you can see a little bit of it up and to the right of the left sub...
Old Mar 24, 2006 | 05:06 PM
RideTuner's Avatar
There's an option to get strobe or non. These are non strobe ones. They light up fine...they just won't go off. I'll try the foot wells...thanks.
Old Mar 24, 2006 | 07:52 PM
n3985's Avatar
大陆弟弟
Consider this:
http://jlevistreetwerks.com/store/pr...e8b3b3f57d6813
Cheap and effective
Old Mar 24, 2006 | 10:23 PM
jsmithsole's Avatar
*moderator*
Originally Posted by n3985
Consider this:
Cheap and effective
See I wouldn't want the spots, I'd want more of an even light shining down. They look quality though...
Old Mar 25, 2006 | 08:35 AM
f*ck autolumination they screwed me over. I ordered from them once, and i will nver order from them again. Gave me horrible quality products, and gave me the run around.
Old Mar 25, 2006 | 09:52 AM
jsmithsole's Avatar
*moderator*
Really? I've bought a bunch of stuff from them and have had no problems. They even let me return stuff when I mis ordered and refunded me before they got the product back. I was surprised on how good their CS was...
Either way, there's this site as well that I have bought stuff from:
http://superbrightleds.com/
Old Mar 25, 2006 | 10:35 AM
kingofsorrow's Avatar
Originally Posted by VQMAX05
Guys,
VQ
wire them into your dome lights. that way they turn on when you disarm/unlock your doors or when you open them, and they will go out when the dome light go's out.
Old Mar 25, 2006 | 10:36 AM
n3985's Avatar
大陆弟弟
Can you tell me where is the dome light wire to tap into? Thanks
Old Mar 25, 2006 | 12:50 PM
ramberg's Avatar
GrandPa
Post pictures when completed.
Old Mar 25, 2006 | 01:27 PM
jsmithsole's Avatar
*moderator*
Yes, like I said in post #2. Don't bother going to the domes though when you can just tap into the wires of the lights in the footwells (that are part of the dome illumination)
Old Mar 25, 2006 | 01:29 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
they have 2002 I35's, I dunno if they have the foot lights like we do..
Old Mar 26, 2006 | 02:21 AM
nah f*ck there customer service they had none, they wouldnt work with my situation. First they sent me the wrong bulb that didnt fit, then gave me defective bulbs and wouldnt swap them out for me. So i reported them to BBB.
Old Mar 26, 2006 | 06:23 AM
whitestunna's Avatar
yeah those are nice i had the regular led tubes on my old car, and here is a link http://www.cardomain.com/ride/717651/1 click on page 2. I had them hooked up to the music so every bass hit the light basically strobes i thought that was bad ***. They also had different settings to go faster and brighter.
Old Mar 26, 2006 | 08:41 AM
jsmithsole's Avatar
*moderator*
Good point, didn't notice the car type!!!
MaxLife17
Jun 27, 2019 01:37 PM
Maxie40
Sep 14, 2015 11:28 AM
minsbang
Sep 11, 2015 08:48 PM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
