Budget of $500 What mod comes first
Old Apr 26, 2006 | 07:46 PM
djfris's Avatar
Im bored so yahhhh.
Ok well I read many forums and found many things you can add to the 6th gen max. My question is if you had 500 Bills to spend on a stock 6th gen 6spd max what would you buy first.(performance wise)
(A) Cold Air Intake
(B) Regualr Intake without the cai
(C) Exhuast system
(D) Y-Pipe
(E) Strut Bar
(F) Drilled and Slotted Brakes
(G)Pulley
(H) Other(Please List)
Old Apr 26, 2006 | 07:52 PM
KUBLKMAX's Avatar
I would say the cold air intake, and some springs
Old Apr 26, 2006 | 07:57 PM
greg hazlett's Avatar
By strut bar do you mean the Rear Sway Bar?
The exhaust alone can kill your budget, I bought mine from Ebay and it was $450 shipped, of course right after I bought it the price dropped...
Will you be doing the installs yourself or will you have to budget labor into the $500?
If you do the work a CAI, UD pulley and the RSB should be right at $500.
Old Apr 26, 2006 | 08:03 PM
mroleg's Avatar
I would say ECU flush. And if Teq gets his thing going it will be a good price and you will have some cash left for a strut bar.
Old Apr 26, 2006 | 08:21 PM
nyjohnny's Avatar
cold air intake
Old Apr 26, 2006 | 08:44 PM
Glude's Avatar
Id start with a rear sway bar and some redline boots to replace the cheapo stock ones.
Old Apr 26, 2006 | 08:49 PM
I disagree with the ECU flash first, unless you never intend to do a CAI, exhaust or Y pipe. I think the ECU reflash should be the last mod so it can take full advantage of the others.
Old Apr 26, 2006 | 10:22 PM
DeusExMaxima's Avatar
Springs and rear anti-sway bar plus install is about $500. This will change the whole handling characteristic of the car, I assure you.
Old Apr 26, 2006 | 11:59 PM
RHMax's Avatar
Newbie just Registered
Or RSB and brakes, if you don't want to springs. Other mods won't improve much by themselves.
Old Apr 27, 2006 | 03:25 AM
gec
with Deus
Old Apr 27, 2006 | 03:43 AM
ramberg's Avatar
GrandPa
It all depends on how many miles you have on your car. Warranty issues on the engine. Do you have a SL or SE?
I would go for FSB and anti-sway bar. Than work it from there.
Old Apr 27, 2006 | 05:01 AM
04BlackMaxx's Avatar
$500 Gasoline fund
Old Apr 27, 2006 | 07:30 AM
minsbang's Avatar
Originally Posted by 04BlackMaxx
$500 Gasoline fund
^^ WHat he said.....
You can fill up your tank about 10 times.
Old Apr 27, 2006 | 08:00 AM
SmokedOutMaxi's Avatar
if you want a performance mod i would wait for the ECU upgrade that tek has.
Old Apr 27, 2006 | 08:05 AM
maxmale's Avatar
absolutly would be my suspension first.
Old Apr 27, 2006 | 08:11 AM
Apollos2's Avatar
Agreed, plus if you already have wheels on the car it will only make it look that much better. My Progress RSB and spring setup installed cost me $600 in Colorado.
Old Apr 27, 2006 | 08:19 AM
maxmale's Avatar
springs/ rsb/ fstb/ cai/ exhaust, all these are easy to put on. my advice is if your not military, find a friend who is and get him to take you to the hobby shop and put the stuff on your self. probably would cost you 30 bucks to do all the mods i just listed.
Smooth's Avatar
cai and sway bar that equals about 500 right there
Old Apr 27, 2006 | 08:21 AM
maxmale's Avatar
or you could rent a spring compresser from an autoparts store. it's more fun when you get your hands dirty and at least you know it is done right.
Old Apr 27, 2006 | 01:07 PM
djfris's Avatar
Well seems every1 here has a diff opinion
So from what I Read screw the y pipe and the cai intake because of the Ecu restrictions and spend some $$$ on the suspension, Kinda wanted the intake but if there are no gains fk it..
Old Apr 27, 2006 | 01:45 PM
kamski's Avatar
.org extraordinaire
Cattman SPRINGS and SWAYBAR.
Then CAI and REDLINE shift and ebrake boots.
Kam
Old Apr 27, 2006 | 02:01 PM
Glude's Avatar
Do the struts and shocks if your gonna lower the car, no point in half assing the job just to replace them later on.
Old Apr 27, 2006 | 02:46 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
no sence in going fast if you can't control it, I say sway bar and springs. this car is plenty fast as is, with control it will feel alot better, and you can take it to higher limits
then do engine mods..
Old Apr 27, 2006 | 06:43 PM
maximob's Avatar
I have CAI and catback, and am really feeling the need for better control. Really itching for springs and swaybar. I think that's a good place to start.
I lost low end power with these two mods, but feel an increase in midrange power. Sometimes I wish I had better control that comes with the suspension mods. Took a ride in VQMAX05's ride and noticed how much a difference dropping and a waybar makes. My package feels incomplete right now and I think will be pretty expensive to get it done...still need y-pipe (waiting for header/y-pipe combo) and ECU mod to start with. Eventually get cams.
Old Apr 27, 2006 | 06:46 PM
djfris's Avatar
So just the springs can be ok, or did you guys replace the struts too?
Where do I get the cattaman springs and the sway bar a website perhaps?
Old Apr 27, 2006 | 08:00 PM
madmik's Avatar
I also think control comes first: RSB, front strut bar, maybe SS brake lines.
Homemade or purchased CAI. Go to MIDAS and get the crimped pipe under the tank replaced with full size tube. Need to get a part time job.
Old Apr 27, 2006 | 08:03 PM
RHMax's Avatar
Call them, I don't think they've update their website, though haven't visit n a while.
I haven't replaced my struts yet, but I'm not too far off.
Old Apr 27, 2006 | 08:09 PM
jsmithsole's Avatar
*moderator*
I agree with most RSB and springs. I ran stock struts for over a year and half with no problems. Then after a while you can upgrade the rest of the suspension. A) Changes the whole look of your car. B) RSB makes a huge difference in handling.
Old Apr 28, 2006 | 12:26 PM
Smooth's Avatar
I installed my progressive tech rsb lastnight...Holy shaaaat what a difference. i though the car was solid before, but after the sway bar makes me feel like I was in a baby carriage
Old Apr 28, 2006 | 12:52 PM
JiuJitsuThug's Avatar
No question - RSB & Springs...
Your car will feel soooo much tighter...
Old Apr 28, 2006 | 02:33 PM
djfris's Avatar
Where Do I get the Springs And the RSB??????????
Im ready just need the website for the springs and rear sway bar??????
Old Apr 28, 2006 | 03:28 PM
kidd4l's Avatar
Cool Member
You can contact Brian at Cattman by email or call him. I think this is the general email address: catt@cattman.com , phone:520.575.6195
There is also a group deal in this forum.
Ronald
Old Apr 28, 2006 | 04:28 PM
ramberg's Avatar
GrandPa
Try redlinemax.com
Old Apr 28, 2006 | 09:53 PM
!PrjctMax!'s Avatar
Did they finally come out with aftermarket performance struts!? Please say it's true! Because I need struts anyways!
Dan
Old Apr 28, 2006 | 11:55 PM
Favs's Avatar
Sorry to go off topic but I am not allowed to start my own thread. IS any one interested in 04-06 Se Wheels 18" stock. If so please contact me at PMPN8EZ052@comcast.net. Thanks
Old Apr 30, 2006 | 02:38 PM
Newblood's Avatar
which RSB is the best? Is that the Cattman everyone is talking about? Is a front sway bar beneficial as well? What springs do you reccomend?
Old Apr 30, 2006 | 03:49 PM
ramberg's Avatar
GrandPa
Check out the stickies.
Old Apr 30, 2006 | 07:05 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Different mods for different goals:
1, speed
2, handling
3, looks
Break down your goals.
If not, get a pair of fuzzy dice...
Old Apr 30, 2006 | 07:09 PM
djfris's Avatar
Speed???? What For Spppppppeeeeeed
Intake
Exhaust
What What What
Old May 1, 2006 | 10:14 AM
chernmax's Avatar
Intake
Exhaust
What What What
For a $500. dollar budget, start with a CAI and UR Pulley.
Than Exhaust, Y-Pipe, and ECU (these 2 need the ECU to achieve true performance potential).
