Brake Job Concerns??New mods
Old May 6, 2006 | 07:11 PM
VQMAX05's Avatar
I am having my car on Monday have a complete spring adjustments.
I am having the MAx
ALigned
Wheels rotated
WHeels re-balanced
Brake Rotors Replaced (RTP slotted/drilled, Carbon Pads)
1 more coat of Bronze paint front/rear
NISMO stickers on calipers done.
And to finish it of
Stillen Front chin spoiler.
Now on 2 the question. To do the brakes, is there anything "special" that needs to be done while doing the job, not to mess anything up. I was told the the car must be plugged into the OBD2 port and have the ABS turned off, as not to mess the system up. Is this true? How much better will the slotted/drilled rotors be over stock?
VQ
Old May 6, 2006 | 07:19 PM
DeusExMaxima's Avatar
I dont know but u better post pics!!!
Old May 6, 2006 | 07:23 PM
NismoMax80's Avatar
SuPeRmOd
I never heard of the special procedures for brakes. No one on here has done so yet. you can find many threads on comparing blanks to cut rotors.
chernmax's Avatar
Nations 1st 6th Gen Turbo
When I did my brakes lines, pads, rotors, etc. No there was nothing special I had to do. No OBD2 and no ABS turnoff (not even sure how to do that other than disconnecting the battery). Just swap your ****, everything should be fine...
Old May 6, 2006 | 07:36 PM
viguera's Avatar
Depends on the pads... IIRC the metal masters require proper bedding in, or they squeak later on. It's a whole 40mph-10mph-40mph-10mph rollercoaster a bunch of times...
As far as ABS/OBDII, I've never heard of that either.
Old May 6, 2006 | 07:44 PM
VQMAX05's Avatar
Good to know about the rollercoaster thing.
I also thought that the OBD2 port thing was weird!
Old May 6, 2006 | 08:29 PM
Monotaur's Avatar
I was thinking of getting metal master pads. Is this procedure documented anywhere?
Thanks!
Old May 6, 2006 | 08:41 PM
chernmax's Avatar
I prefer HAWK and so far they have performed excellent...
Old May 6, 2006 | 08:44 PM
NismoMax80's Avatar
SuPeRmOd
i thought that was common knowlege atleast if you read the box. i meant as far as install
Old May 6, 2006 | 09:03 PM
RHMax's Avatar
Newbie just Registered
Originally Posted by VQMAX05
... I was told the the car must be plugged into the OBD2 port and have the ABS turned off, as not to mess the system up. Is this true? ...
As long as you don't turn the key to accessory (radio) or ignition, you don't need to disconnect the battery or ECU. If you turn the key and someone step on the brake pedal, the pistons will pop out. And you'll have to have the car tow to da steala...
kamski's Avatar
.org extraordinaire
I just installed the wilwood BBK and that was the same procedure listed on mine...... I guess it must be standard procedure.
Kam
Old May 7, 2006 | 06:56 AM
KCMAXX's Avatar
KC's FINEST
???? Ever done a brake job? C clamp bro...
Jon, I love my drilled rotors. They do dust for awhile and I can faintly hear the tick-tick of the pads at certain speeds. Nothing special is needed to do brakes...
Old May 8, 2006 | 11:50 AM
madmik's Avatar
I have drilled/slotted rotors, zinc treated (no rust). They add a small 'wizzing' sound and feel when you brake. I think they look better than slotted only rotors. Braking power was slightly better. Get Stainless Steel braided brake lines with the brake job if you can (search previous posts or sticky). It adds much more firmness to brake pedal.
NISSAN service manual calls the 'rollercoster' burnishing the brakes.
30mph down to a stop in 3-5 seconds. Drive 1 minute to cool brakes.
Repeat cycle 10 times or more.
No mention in service manual about ODBII connection for any brake work. Stealership scam probably.
Max service manuals are available at:
http://www.phatg20.net/modules.php?n...titleA&show=10 (credit to Ramberg). A must for diy's.
Old May 8, 2006 | 12:43 PM
RHMax's Avatar
You are the only one that has ever done a brake job, bro... But that was not the question, was it, bro?
Old May 8, 2006 | 12:52 PM
Glude's Avatar
No, but stating that you need to go to the dealer because the piston is out...
Old May 8, 2006 | 01:20 PM
RHMax's Avatar
You laugh, but I've seen some crazy $hit at the shop. Most manufacturers recommend disconnect battery when working on ABS brakes, so the modules don't get screwed up if some idiots does something stupid.
Mar 12, 2020 12:06 AM
05RLS2
Sep 27, 2015 09:24 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
A32goldylocks
Sep 2, 2015 06:39 AM
