Ordered front sway bar from Altima SE-R
Is there a way to let me know which bolts I undo on the subframe. Its a bit confusing. Perhaps a picture with some arrows on it would be great. Also, do i need to remove the rear engine mount, or remove something on the rear engine mount?
There are four huge fasteners on the subframe. You can't miss them when you get under there. The rear two need to be removed and I believe they are nuts. The rear motor mount needs the long horizontal bolt removed from it so the subframe can drop away from the motor/trans.
Originally Posted by DeusExMaxima
I noted the large fasteners - 17mm or 19mm I think - but I also saw some brackets that appear to be involved. Is that true?
All bolts off except motor mount bolt. I admit, removing subframe bolts is scary cuz it better line up when I put it together. I noticed the subframe dropped a bit, even though I am supporting engine/tranny with a floor jack. Once I figure out the motor mount removal, its time to pry the subframe. There is either one bolt in the middle of the mount, or two bolts at the bottom. Im going to research it and find out which needs to come off. I tried to remove the bar without having to drop subframe, and its impossible. Too many curves in the bar. So far, its been stright forward. I am using air tools and I bought $100 worth of 1/2" drive hardened sockets that are wonderful.
Kamski
Originally Posted by MAXDOUT04
Hey Kam sorry for O/T but did you ever get that stillen front lip painted and installed yet? also dues hows it coming so far
LOLLOLOLOLNo no, I'll get it on, still need new bumper and grille. Will do all at the same time.
Kamski
deus i hope everythings coming good...i hope you don't miss allign anything when putting everything back together. good luck we are all looking forward to seeing if this will be the next step in handling perfromance mods.
THE BAR IS OUT!!!! Prying that subframe was really a bzitch, but I got it!! Its hard to tell the difference between the OEM bar and the SE-R bar, but using a 15/16" open end wrench, the wrench easily slides over the OEM bar with 2mm gap, whereas the SE-R bar wont allow the wrench to fit over it.
Here is a pic of the bars side by side with wrench over OEM bar:
Here is pic with wrench over SE-R bar:
Here is what it looks like when you work in 102 degree temperatures, 100% humidity, and you have to remove a front sway bar:
Time for a dinner break, and Ill see how far I get on the install.
Do they look the same? It WILL FIT right?
Kamski
They look EXACTLY the same, except the SE-R bar is thicker. I am confident it will work.
Props to you for trying it out
I'm next
Kamski
Lets see how the install goes . . .can't to try and get that subframe back up. The alignment should not be affected at all. I'll make some time for the install later this afternoon. And, of course Ill keep u posted and take plenty of pics.
Originally Posted by RHMax
Is the SE-R bar heavier, or just thicker?
Originally Posted by !PrjctMax!
I'd assume that it would be a little heavier, considering that the 2mm more of metal and that I believe that it's solid so that would make it heavier as well; but not more than a few pounds imo just like the rear OEM sway bar compared to the Progress/Cattman bar.
Im in the home stretch!! Sway bar fits perfectly!!! I just need to tighten down bushings and bolt in Y-pipe and put wheels on. I'll start another thread regarding how to install and results.
Kamski
DISASTER STRIKES!!!! I started the car and the steering somehow got disconnected!!!! When I turn the steering wheel, its doesn't turn the wheels. It feels like its disconnected!!I cant understand how that happened. Im gonna get underthere and find out. I hope I dont have to redo this!!
I went under the car to check out the steering rack. It looks fine. I had someone turn the steering wheel, but I couldnt see anything moving leading me to believe that maybe the column broke inside the car when I dropped the subframe down. The steering rack is bolted to the subframe, of course. I need help!!!
Check the splines. The shaft runs into a spine and held with a clamp. It is possible the spline (male side) slipped out when you dropped the subframe. Hopefully you can loosen the clamp and slip the shaft back in the femal side and reclamp it (no pun intended!).
