Ordered front sway bar from Altima SE-R
#122
![](https://maxima.org/forums/images/smilies/support.gif)
I found the problem!!! I have been racking my brain trying to figure out why the steering is affected because of changing the front sway bar. Last night, in the middle of the night, I thought about how the steering column connects to the steering rack. It connects INSIDE THE CAR. So, this morning, I looked under the dash, and lo and behold, the steering column was hanging out of the recpetacle. The end of the column has splines that slide into the recpetacle for the steering gear box. When I dropped the subframe to install the sway bar, it pulled the end of the steering column out.
Here is a pic:
![](http://i4.photobucket.com/albums/y123/Apxl8r/PICT0510.jpg)
Im holding the end of the steering column. To the right is the receptacle that the end of the column slides into.
The good news is nothing is broken. The bad news is, I either have to drop the subframe down again and stick the end of the column in, or remove the steering column and stcik the end in.
I'll likely elect to drop subframe down, make sure wheels are straight, and then slide the column in.
Here is a pic:
#123
Nations 1st 6th Gen Turbo
![](https://maxima.org/forums/images/Maxima_OTM.png)
Here is a pic:
Here is a pic:
Glad everything is OK now, your situation made the hairs stand up on my arm...
![Oh noes](https://maxima.org/forums/images/smilies/ohnoes.gif)
#125
Here is a pic:
Here is a pic:
#128
I answered my own question. The male splined shaft unbolts from the universal joint. Then, the universal joint unbolts from steering shaft. I cant seem to get the male splined shaft into female receptacle u see in the picture above (I know, sounds like a personal problem!!!). Once that goes in, I think i'll be done. I am cleaning the splines and lubricating so it will slide in.
#129
ooo man...i kno that was a weight off your shoulders rah there...congratz. buh yo seriously...after this problem solved take it easy at first...cause you don't kno the full extent to the problem if its even solved...then once you feel comfy enough then see if your handlings got better or not. BUH SAFTY FIRST...
#130
Still trying to get the steering joints to fit. I got the spline into the female receptacle. I removed the universal joint, and slipped it on the spline shaft. I am about 1/4" away from getting iniversal joint on the steering shaft. I may have to drop subframe a couple inches. Still working . . . . .
#131
Ok, I did the quickie version of dropping the subframe and I got the steering joints back in!!!! Now I just have to bolt it back together, and Im good to go. Look for new thread for reals!!
#135
#138
Car handles very flat and it tracks well through the turn. Front feels tighter. Its amazing how 2mm of thickness can make a difference. I'll post more comments as I run it through more corners.
#140
Congratulation Deus... Real nice job and Im glad everything worked out. Now where do we buy the bar from, any Nissan dealer? Do we just need to tell them the part numbers (The BAR: 54611-ZB700
Clamp: 54614-8J0000
Clamp: 54615-8J0000
Bushings: 54613-ZB700 <-----You need TWO of these)
we need or what?
Clamp: 54614-8J0000
Clamp: 54615-8J0000
we need or what?
#141
I would give them the part numbers, cuz we know for a fact that these are the right numbers. I believe you can order these at any Nissan dealer. I went to Performance Nissan because I have dealt with them before and I like the name. By the way, I feel the bar working when you go over uneven bumps or if you go over a ditch at an angle. It resists bottoming out too which is nice.
#148
Steering feels a bit funky, but its because it slipped out of the steering box. It has nothing to do with the sway bar. I will try to spend some time trying to figure out what the problem is.
#149
Kamski
