Steering column sqeuak....
When turning at low speeds there is an annoying screech from my steering column........any ideas/suggestions? I haven't seen any threads on steering column squeaks so please don't
me
Dan
me
Dan
Originally Posted by MAXDOUT04
Is it a plastic or a metal noise being heard cause i had a plastic sound coming from mine and i just banged the crap outta my wheel and it stopped? weird but it worked
But, i'll try your "method!" lol I do it with so many other things and it works jsut like you said, so why not try it on my car?!
Originally Posted by Glude
That sucks, my whole steering column moves up and down. It looses somehow, been that way for a while. I REALLY need to get that fixed.
wow that's not good!
My steering wheel did that in the beginning and took it in for service and they fixed it no problem but what he did to tighten it up im not sure but its tight again
Yeah, its been like this for a while now so its obviously not hurting anything but I really need to get it fixed.
Does it move in like a diagonal direction(from like passenger side top of windshield to bottom of drivers door) thats what mine was doing?
Originally Posted by mr.b
Mine has started squeaking recently when it's auto adjusting to my key fob. I'll be getting in and hear "eeerrrrrreeeeee"
Have you noticed if your is temperature related?
Originally Posted by Killah Kane
Well, my steering wheel squeeks when I get in and out of the car as the steering wheel moves upon exit and re-entry. Its very annoying, anyone know of a fix?
Originally Posted by Monotaur
Nope, I've had the same thing when it is hot outside. Does yours only happen when it is hot in the vehicle (like when you first get in on a hot day)?
Hmm, I dont know. I havent noticed the temperature during the squeeks, I will start looking at the temp. now when I hear the squeeks and will let you know
Originally Posted by SMX95
Dry clock spring, remove airbag and re-lube.
Originally Posted by vsamoylov
. .... but most people wont fix it because it requires the removal of the airbag
Just handle the airbag like you would handle any EXPLOSIVE, with care. It needs electricity to ignite. Disconnect the battery and wait 2-3 minutes. One 10mm bolts on each side of the cover under the steering (chk service manual). I took mine out a few days ago to replace one of the steering cover.
Originally Posted by coitaltie
thats good to know bc when it is hot, mine squeeks as well. Im getting the steering coumn repaired as well as there is a click or "give" in the column when driving. It is subtle, but noticeable nevertheless. The dealer actually agreed with my issue as I thought they would blow it off. i will bring up the clock spring.
I have the same click going on and one dealer blew me off stating that they didn't find anything. I showed it to the guy and he says he sees the problem, bring it in next week will fix it. I pick up the car and its doing the same thing. He tells me they tighten up everything but thats about it. I went to another dealer and he ordered entire steering column because he says they whole thing has too much play. It is currently on backorder but I hope that when it comes it will fix the problem.
As far as removing the dash.....I would never agree too it again unless nothing is working. From when I bought the car the blower would not blow air around the feet so I went back and they took apart the whole dashboard only to order parts. Went back week later, left it for a day, come back to pickup and they said they need to change the entire assembly because the part didn't fix the problem. Come back again and its fixed.........BUT
every time I hit a pot hole the whole dash just rattles. It feels like the car is bottoming out almost every time. My brother also has a max and his is smooth over the holes. We both just changed our suspensions and his is still smooth while mine is even worse. CRAP!
worldwiderecognized
Sep 30, 2015 01:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
