Low fuel vol. reading on obd II after header/y install
Old Aug 7, 2006 | 09:27 AM
chad9350's Avatar
Low fuel vol. reading on obd II after header/y install. has anyone else encountered this?
Pressure is good, volume I am low.
Old Aug 7, 2006 | 01:05 PM
kamski's Avatar
.org extraordinaire
Time to send ECU to technosquare.
Kamski
Old Aug 8, 2006 | 04:48 AM
chad9350's Avatar
Planning on it, want to get a dyno run w/ NEO to send w/ ecu to make sure I get most out of the flash...
So, no fuel pump, pres. reg. changes needed??
Apprec.
Old Aug 8, 2006 | 06:25 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
you are too lean, all these mods lean out the car, you need a piggy back or the ecu done..
lean: too much air and not enough fuel..
the guy at TS, doesn't run fuel REG's, you don't need that, just some fuel added by terms of piggy back or ecu..
I wouldn't run it like that for long, get it done quickly..
Old Aug 8, 2006 | 09:39 AM
ecks's Avatar
I piss on Civics.
my max reads about 24mpg for normal driving but i hope to get closer to 30 on my upcoming roadtrip
Old Aug 11, 2006 | 07:23 AM
chad9350's Avatar
Neo
Getting neo installed, and getting a roller run mon, tue, or wed. .. so I can send maps w/ ecu to TS, and to (hopefully) cure fuel problem.
BTW car is parked, not driving it that way at all
Old Aug 11, 2006 | 07:46 AM
DeusExMaxima's Avatar
Whats NEO?
Old Aug 11, 2006 | 08:01 AM
Glude's Avatar
Shouldnt you be able to tune the car with the NEO and not require TS flash? If you have an a/f fuel controller id just get the L spec flash, otherwise your just wasting money IMO.
JRod28
Dec 29, 2023 09:56 PM
Cotozic
Jun 28, 2017 08:01 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
