Lowering and Camber
Lowering and Camber
How many of you have lowered your car and then put in camber bolts. I did mine on Saturday and had the alignment checked today and it's WAY off. They can't even adjust the camber back into spec without camber bolts. Do you guys just not care about tire wear or was I just not paying enough attention to needed parts? Any help would be greatly appreciated.
Thanks!
Thanks!
yeah im also in question about this..... i want to lower my car and can already tell without even lowering it .... that i have a bit of negative camber in the back... im riding 20's so i should expect this..... can anyone recommend a good camber kit? i intend on buying the progress lowering springs and shock/strut set from cattman
thanks
thanks
I had my alignment checked after installed Progress springs. The camber is negative but only about 1 degree; the track was straight, didn't need any adjustment. After almost 12k lowered miles, tires worn pretty evenly, don't show more wear on the inside than outside. I do rotate them every 6k miles.
I rotate my tires every oil change so I know the impact will be minimized. 1 degree is a quite a bit to off though; especially when you consider they give a window of 1 1/2 degrees to work within. I know that you can achieve better cornering with a higher degree of negative camber but it also slows you down and is not good for extended highway which I frequently do.
MaxLvr21
Oct 17, 2015 12:11 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
