6spd transmission bad
Old Sep 8, 2006 | 11:56 AM
haunt14's Avatar
i have an 04 max se wit 6spd, it has 44k on it and its on its 4th transmission under warranty. i have owne 3 other cars in manual and none have ever had the clutch or transmission replaced. do any of you guys know if this is covered under lemon law in nj, any info would really help. nissan is no help with this situation. thanks.
Old Sep 8, 2006 | 12:01 PM
MAX2DAMAX's Avatar
it should, 3 times for the same problem, you should be able to lemon that thing, i think
Old Sep 8, 2006 | 12:10 PM
haunt14's Avatar
i hope so, cause it seems like this is i never ending problem. i love the car so much too, this sucks
Old Sep 8, 2006 | 12:38 PM
RHMax's Avatar
Newbie just Registered
Is it 4 bad tranies/clutches in a row, or somethingelse to cause the tranies/clutches to go bad? The lemon law should apply, depending on the documentations. Good luck.
Old Sep 8, 2006 | 01:09 PM
CanadianMoFo's Avatar
Sorry to hear about your luck. Hopefully it can get resolved without too much fighting with the dealer.
Old Sep 8, 2006 | 01:49 PM
d00df00d's Avatar
Old enuf to pick his own gears
If it's 4 clutches, they could easily make the case that your driving killed them.
If it's 4 transmissions... Lemon. There is probably some weird problem that's causing unusual stress and breaking them.
Old Sep 8, 2006 | 02:17 PM
bluemaxx's Avatar
Moderator GT-R
Was it four repairs on the same transmission or four new transmissions? I have 55k on the original clutch and transmission. It is stress tested on a regular basis, so far no protestations.
Old Sep 8, 2006 | 03:15 PM
MDS's Avatar
MDS
What keeps breaking on the transmission?
Old Sep 11, 2006 | 11:54 AM
haunt14's Avatar
im not exactly sure what keeps breaking, they just tell me there ordering a new one, ther second time they said the pinion was bad. the clutch was only done once and i think they just did to get some cash from me. cause i have never wore out a clutch in my life. they still got the car it should be done today or tomorrow. i think im just gonna get rid of it and start wit a new car. this has been the worst experience ever. i bought new to save the headaches and yet this car is worse then every used car i have owned.
Old Sep 11, 2006 | 12:14 PM
Glude's Avatar
That sucks, im at 57k and havent had any problems. I bought my car new for the same reasons, didnt wanna get stuck with a used car with problems.
Old Sep 11, 2006 | 01:13 PM
d00df00d's Avatar
Find out what broke each time. The service records should be available to you. Just walk in and ask for them, and don't leave unless you have every detail. That information will be very important as ammo if it reveals that you have a lemon
Old Sep 11, 2006 | 04:38 PM
RHMax's Avatar
The problem could just be the dealer itself screwing your car up after the first visit.
Old Sep 11, 2006 | 08:50 PM
twintz1991's Avatar
i cant imagine going through four clutches unless you have too much power and clutch cant hold it. maybe its time for an upgraded clutch
Old Sep 12, 2006 | 03:18 AM
haunt14's Avatar
i went through four transmissions, not clutches. and i got the history from the dealer, all it says is replaced transaxle. what ever that means.
Old Sep 12, 2006 | 05:48 AM
d00df00d's Avatar
I think that qualifies the car as a lemon.
What were the symptoms each time?
Old Sep 12, 2006 | 05:52 AM
xoomer.com's Avatar
I Donate! Why Don't You?
Not a mechanic but from things i've see things are misaligned somewhere.
Damn and I though I had problems with mine. Yep, after gazilion visits to the dealer for gazillion different problems I am getting the entire steering column replaced. I bought brand new with 7, yes 7 miles on it so that I wouldn't have any problems unlike with the pre-owned jeep. I love this car but the problems keep on coming.
Old Sep 12, 2006 | 02:20 PM
aryathegreat's Avatar
my tranny went bad as well a couple months ago (auto) and it was due to the a burned clutch. the auto clutch that is. anyways, my point is that i heard things from nissan that in the past, companies have made up that therethere is a major problem with someones car such as the tranny, get new parts, and dont put it on ur car. they make a couple thousand on those kind of things. just thought maybe if it goes "bad" again, u could mark ur tranny with a mark and see if they really did anything or they are just pulling ur leg.
Old Sep 12, 2006 | 02:55 PM
MDS's Avatar
MDS
Dude, you're 16 years old and have a Maxima? Damn!
Old Sep 12, 2006 | 03:35 PM
rabenoja's Avatar
I had to have my tranny replaced at 23K...of course it was under warranty but, I think it's a problem with these cars. I had it replaced because I lost one of my gears....they said it was the short shifter that caused the problem. Luckily, they replaced it. The new tranny still grinds and I think my clutch is now wearing out....I have 43K on the car right now.
I'll see if I can get it replaced again but, it may still grind.
Good luck with your car, and I would try the lemon law in your case.
Old Sep 13, 2006 | 06:20 AM
RVC's Avatar
RVC
Do yourself a favor...google New Jersey lemon law and find out what constitutes a lemon. Then get yourself a reputable lawyer. Nissan is the worst for rectifying a lemon. Trust me I know, my car is a lemon and Nissan is re-purchasing it after a long drawn out battle. It's an 05' Maxima.
Old Sep 14, 2006 | 07:10 AM
haunt14's Avatar
im gonna try, what is wrong with your that there re purchasing it?
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
The Wizard
24
Oct 1, 2015 08:47 PM
