Cosworth heads
Old Sep 23, 2006 | 08:33 PM
DeusExMaxima's Avatar
Cosworth heads
I found this on ebay:
http://cgi.ebay.com/ebaymotors/Coswo...31796763QQrdZ1
This is an expensive mod, but its an alternative to turbo power. The heads are ported, cc'd and larger valves are used. I bet just adding these heads will get you get 40-50 horses. If you throw in cams, for another 20, and all the usual bolt on mods, I bet 100hp is no problem.
Obviously, since these are expensive they arent for everyone. What do ya'll think?
Old Sep 23, 2006 | 09:06 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
hell yea!, cosworth is damn expensive, but good stuff..
Old Sep 23, 2006 | 11:21 PM
Nietzsche's Avatar
Maybe when I blowup my motor.
Old Sep 24, 2006 | 06:21 AM
madmik's Avatar
Easier to get warranty work done for sure. Not as obvious as a big as@ turbo in the engine bay.
Its a top name but you also have to spend even more big bucks to allow more air/fuel in, and better exhaust. You get into resizing the injectors=> reprogram the ECU. $$$ I never calculated how much WHP we can get out of the stock injectors, but I suspect once we pass 260-270WHP or something, a whole new fuel delivery system is in order. Not sure how far you can go by just increasing fuel pressure.
Old Sep 24, 2006 | 08:54 AM
ramberg's Avatar
GrandPa
Are they better than Hot Shot headers?
Old Sep 24, 2006 | 10:00 AM
Tek-Niq's Avatar
our injectors are good for 300-330hp I belive since we have 330cc injectors from factory.
Old Sep 24, 2006 | 12:46 PM
AllBlackMax's Avatar
aka The Doom Ship
I think Cosworth is coming out with a VQ35 crate engine soon.
Old Sep 24, 2006 | 01:05 PM
gen2000's Avatar
Have you taken a look at this. Might get you a little more grunt. Definitely a torque monster.
http://www.aebsracing.com/products.p...ct=vq35stroker
Old Sep 24, 2006 | 01:07 PM
Apollos2's Avatar
WOW That looks like major surgery to get those put on, wonder how much that would cost for install. If I had the money I think I would go that route instead of a turbo/SC. Just seems like a more substantial and foundational piece to build on. 40-50whp would be huge in one single mod.
Old Sep 24, 2006 | 01:16 PM
STARR's Avatar
Very nice, 2 questions what does the DE at the end of VQ35DE stand for, the new VQ is HR which is High Reving and with all this power is the stock 6speed & auto 5 and 4 speed gonna be able and willing
Old Sep 24, 2006 | 02:07 PM
kamski's Avatar
.org extraordinaire
So Ideal ASPIRATED engine for the 6th Gen would look like this.
AEBS 4.2L low compression kit. Turbo 8.5 : 1 / 100mm, engine size 4231.16cc
Cosworth HI-Flow heads
Squires Twin Turbo Remote mount system with intercooler @10lbs.
Nismo Cams
HotShot Headers, heat wrapped.
Technosquare Tuned ECU.
Hi-Flow injectors and and pump
Oil Cooler
I bet 425-450WHP is possible with the above toy.
So Ideal NON-ASPIRATED engine for the 6th Gen would look like this.
AEBS 4.2L N/A 11.5 : 1 / 101.5mm, engine size 4269.35cc
Nismo Cams
Hi-Flow injectors and pump
Oil Cooler
I bet 350WHP is possible with the above toy.
What do you guys think, also full syn***ic oils and hi-performance gaskets everywhere.
Kamski
Old Sep 24, 2006 | 02:20 PM
SuperStasiu's Avatar
Totally different item mang. These are heads, the part where your camshafts sit.
Old Sep 24, 2006 | 02:23 PM
aka The Doom Ship
I'll take the high compression config. Just no room for turbo and my Hotshots remain a good investment.
Old Sep 24, 2006 | 04:34 PM
kamski's Avatar
.org extraordinaire
DUDE, I GUESS you dont knwo what an STS turbo is.
Well let me show you.
http://www.ststurbo.com/single_mustang_install_pics
You dont need room dudley
Old Sep 24, 2006 | 05:09 PM
aka The Doom Ship
I know all about the STS setup. I also know they don't have a setup for our cars. And, I don't want all that piping under my car. My car weighs enough as it is.
Old Sep 25, 2006 | 03:16 PM
kamski's Avatar
.org extraordinaire
+100lbs +100hp = 200x more fun
Ok............. so a twin turbo Squires maxima is out of the question? I seriously think a well built engine with the remote mount setup could be a
killer powerhaus.
Cause I see a lot of the G35 twinturbo threads and 350Z twinturbo threads.....
And who is Carlon Mencina?
Kamski
Old Sep 25, 2006 | 03:40 PM
nismology's Avatar
I clicked on this thread expecting a serious discussion..........
Old Sep 25, 2006 | 04:01 PM
Glude's Avatar
Duuuude, duddd, duddddddeeeee!! Image twin turbo, low spool turbos at @10lbs!! GLOGHSALKSJDHAGKLSLHLKH (INSERT DROOL HERE).
Tee hee hee
oh god, please tell me u didnt just do the Carlos Mencia thing. His show sucks, he sucks at life, and hes a
Old Sep 25, 2006 | 04:40 PM
NmexMAX's Avatar
dot dot dot ...
Old Sep 25, 2006 | 05:21 PM
kamski's Avatar
.org extraordinaire
Buzz Kill Central over here
Old Sep 25, 2006 | 05:46 PM
05BlackSE's Avatar
I wouldn't mind some of these....
Old Sep 25, 2006 | 06:22 PM
NmexMAX's Avatar
dot dot dot ...
How about a set...
Old Sep 27, 2006 | 04:47 AM
04BlackMaxx's Avatar
Nismo Cams
Oil Cooler
Nismo Cams
Oil Cooler
Kamski
Both ideas are aspirated (that just means they breathe air) but stock is naturally aspirated and turbo is forced induction.
Old Sep 29, 2006 | 02:52 PM
chad9350's Avatar
3500$$...
3500$ for only 50hp... not incl. labor, headache, etc...
...wouldnt it be ALOT easier to get a 75-100 hp shot... jus my 2
Old Sep 29, 2006 | 05:44 PM
Nietzsche's Avatar
Difference is nitrous is for *****'s. Those babies give you power all pedal all the time.
Old Sep 30, 2006 | 05:24 PM
madmik's Avatar
I see your point about NOX being on/off. I think I would rather spend the $$ on a turbo first. If I ever change or port the heads, its because I am also adding better rods, pistons, cams, intake.
If you ever enter a car show, which mod do you think will get the most awe and praise: the Cosworth heads or the twin Turbos? Either way will require major front end upgrade to get the power to the ground. That's why I am only looking at exhaust, ECU upgrade and other common mods for now.
Old Sep 30, 2006 | 05:44 PM
Nietzsche's Avatar
Twin turbos are always going to give you the wow factor. Personally I'm a NA kinda guy.
Old Sep 30, 2006 | 10:55 PM
Yeah Id rather be NA. Its more stealth.
Old Oct 1, 2006 | 06:32 AM
Defiant_Max04's Avatar
Cosworth was teamed up with Mercedes back in the day to create their racing division line of cars, like you have the AMG today. This is some serious ****!!
Old Oct 1, 2006 | 09:21 AM
I know its expensive and its not for most people, but i think its a great way to go for serious HP because these heads flow and Cosworth is very very reputable. They will make everything else you have done to the car, work better.
Old Oct 1, 2006 | 11:04 AM
nismology's Avatar
There are cheaper ways to make good power on an n/a VQ35. Porting and polish the existing heads, raising the compression to 11.5:1, throwing in some cams like JWT's or Tomei 264/268's, and/or a modified stock manifold or Z manifold. A built head should be the VERY last thing you do if you're staying n/a.
Old Oct 1, 2006 | 05:40 PM
darrinps's Avatar
These might yield more power and they might not. If everything else is stock, then my guess is that they wouldn't do a whole lot. Change the cam and computer to deliver and make use of the POTENTIAL the heads give then yes...they could add quite a bit.
Just sticking on a set of heads won't improve anything though unless the ones they were replacing were already at their limit (restrictive) with the other related components. Oh, and they will reduce your compression ratio everything else being equal (same gasket height, same pistons, etc.).
BTW, the price they are asking is highway robbery. Think of it this way, why would a set of 6 cylinder heads cost three times as much as a set of V8 heads of the same quality (Roush, Ford SVO...errr...what used to be SVO, ARP, etc.). Answer: Because folks are willing to pay that much I guess.
Old Oct 1, 2006 | 06:39 PM
Until someone comes out with cheaper priced heads . .
Old Oct 1, 2006 | 07:07 PM
NmexMAX's Avatar
dot dot dot ...
Optimize the set-up before thinking that the more money spent the better.
Old Oct 1, 2006 | 10:30 PM
kamski's Avatar
.org extraordinaire
Squires Twin Turbo Remote mount system with intercooler @11lbs.
Nismo Cams
Nismo Hi-Flow injectors and and pump
Oil Cooler
Would that make sense, what could this engine possibly develop? HP/TQ?
Thanks for the input.
Kamski
Old Oct 2, 2006 | 02:54 AM
nismology's Avatar
You can't just throw parts and money at a car like that man...
What are your goals?
Old Oct 2, 2006 | 08:14 AM
kamski's Avatar
.org extraordinaire
500HP like the modded S4 bi-turbo, now I know its a lot of HP for a front wheel drive car but can it be done, or do you have to re-inforce the mounts, tranny etc?
I guess this is a generalization but for me If i had this coin I would track this car at Mossport here in Ontario. Plus once can never have enough HP
Kam
Old Oct 2, 2006 | 02:13 PM
NmexMAX's Avatar
dot dot dot ...
Squires Twin Turbo Remote mount system with intercooler @11lbs......
These 2 cannot happen together. And Technosquare, at the moment, has no F/I program for any FWD VQ.
If you got it, why not ------>
Old Oct 2, 2006 | 02:34 PM
aka The Doom Ship
My suggestion would be, if you're serious, take your car to a reputable shop and tell them what you want.
If you want NA 400hp or 400hp FI tell them that. 400 NA power will probably cost more because they will probably have to go into the engine.
On the other hand turbo will be expensive because they will probably have to fabricate custom exhaust manifolds.
The shop that did my headers didn't seem intimidated by the idea of a custom turbo kit. I think if I had about 15K they would do it.
Old Oct 2, 2006 | 02:59 PM
JiuJitsuThug's Avatar
If you want 400hp just save yourself the hassle and buy a TRUE sleeper sports sedan - Caddy CTS-V or SRT-8. The CTS-V comes stock with 400hp, runs a 4.3 0-60 and has a top speed of 165. Also has winning RACE PROVEN performance that will smoke maxi's day in and day out. Throw a Magnussen or Mallet SC on the CTS-V and you will have 500hp and no max will even be able to breath your exhaust fumes.
After all of your expenses of trying to make 400hp on a FWD Nissan, you would have spent more money on the Nissan than a true sports car and are still stuck with a FWD car IMO.
