Cosworth heads
Old Oct 2, 2006 | 04:54 PM
  #41
AllBlackMax's Avatar
aka The Doom Ship
Originally Posted by JiuJitsuThug
If you want 400hp just save yourself the hassle and buy a TRUE sleeper sports sedan - Caddy CTS-V or SRT-8. The CTS-V comes stock with 400hp, runs a 4.3 0-60 and has a top speed of 165. Also has winning RACE PROVEN performance that will smoke maxi's day in and day out. Throw a Magnussen or Mallet SC on the CTS-V and you will have 500hp and no max will even be able to breath your exhaust fumes.
After all of your expenses of trying to make 400hp on a FWD Nissan, you would have spent more money on the Nissan than a true sports car and are still stuck with a FWD car IMO.
The ONNNNLLLLYYY thing you'll be sacrificing is interior space in the CTS-V. If you're tall like me(6'3") and my size(300lbs), you'll be quite cramped in a CTS.
Old Oct 2, 2006 | 05:17 PM
  #42
kamski's Avatar
.org extraordinaire
Originally Posted by NmexMAX
These 2 cannot happen together. And Technosquare, at the moment, has no F/I program for any FWD VQ.
If you got it, why not ------>
HotShot headers and heatwrapped to keep the heat thrust for the turbine.
Since the STS turbo is mounted in the rear of the car I would want to use the heatwrap to keep the exhaust velocity at optimum to reach the rear turbos, then use a front mount active intercooler to chill the charge.
As for the ECU, Jay at technosquare said he could create a generic program, clone a G35 or Z350 F/I program apply it to the maxima for testing, then once its dynoed send him the A/F charts and he'll modify it to optimum tune.
So anywhoo.............. a 6th gen maxima is gonna get F/I sooner or later
Kamski
Old Oct 2, 2006 | 05:54 PM
  #43
NmexMAX's Avatar
dot dot dot ...
I guess I'll leave now that N/A has left the idea.
Old Oct 2, 2006 | 10:11 PM
  #44
kamski's Avatar
.org extraordinaire
Ok, if you wanted to build the "monster" VQ N/A would you use the Cosworth Heads?
I mean, stroker kit, cosworth heads, cams, headers, Fuel Injectors
Also stupid question, does a larger displacement engine run more "rough" then a smaller one? Just for curiosity sake.
Like a stroker kit VQ would it run stupid rough or fairly decent?
Kam
Old Oct 2, 2006 | 10:50 PM
  #45
Nietzsche's Avatar
Should run smooth. Pathfinder is butter.
Old Oct 3, 2006 | 03:55 AM
  #46
nismology's Avatar
I think you oughta visit my350z.com and search to see what people there have done n/a.
I don't even know where to start.
Not necessarily. The only reason the 3.5 isn't as smooth as the 3.0 is because of the higher rod angle caused by the lower rod:stroke ratio, not because it has "more displacement".
There is plenty you can do n/a with the 3.5 without touching the displacement. It still seems like you just wanna throw parts and money at the car without doing any research. Like i said before, visit my350z.com and search so you can get a REALISTIC idea of which mods do what and which route to take.
knight_yyz
Nov 1, 2015 01:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
jaydot901
Sep 29, 2015 01:18 PM
