Rad Hose Leak
Rad Hose Leak
I have a leaking upper rad hose on my '04 SE w/87,000km. It isn't pissing coolant (yet) it's just sweating a bit.
(excuse the camera phone pic)
It only seems to leak a few drops per day, but you can see the coolant pooling up on the hoses below the rad hose.
I intended to put in fresh coolant before winter hits anyway, but it looks like I'll be installing a new rad hose as well. Is this a common problem? If it is a is there a fix for it, other than swapping and cleaning the area the hose which I will do anyway?
HADA 11 - Is the coolant seeping through a hole in the hose, or between the hose and the tube/pipe it is clamped to?
If there is a hole in the side of the hose, it must be replaced, and I wouldn't wait. It will only get bigger.
If, however, the coolant is seeping out between the hose end and the tube it is clamped to, the problem is not the hose; it is the clamp not squeezing the hose tightly enough.
If this clamp is spring-loaded (non-adjustable), I would take the hose off, clean the surface between the hose and the tube, then put the clamp back on.
If the seepage is still there, I would either replace the clamp with a new Nissan OEM clamp just like the old one (this is assuming the old one was slightly weaked from age), or (probably better), replace the clamp with one which has a screw-type adjustment that enables it to be tightened very firmly against the pipe. These are available at most automotive stores.
I just got in from flushing the rad fluid. I pulled the suspect rad hose and there were no holes. However there was alot of ****e around the flange that was either some sort of sealant, or more likely dried out coolant that was causing the leak. I think there may have been some capillary action going on helping the coolant out.
I replaced the clamp with a SS Screw/Band Clamp.
FWIW I used Nissan Spec Coolant. Flushed the coolant system with distilled water until the water ran clear. I then drained the rad and filled it with straight coolant. The distilled water in the block + the coolant in the rad should give me close to a 50/50 mix.
If you happen across this post looking for info on coolant and haven't read the "Fluids and Lubricants" section on this site I suggest you look there for more info.
litch
123
Jan 4, 2024 07:01 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
