Two Things Going On.. Advice Please!
Old Oct 12, 2006 | 07:33 AM
MK101's Avatar
Hello all! It's been a while since i've been on here!
Ive got two things going on with my Max. First off, I just installed the Fujita CAI (which is drool worthy!) and now my check engine light is on constantly. Anyone know how to correct this or if the dealership can reset it?
Second, my suspension is popping a lot. I go up and down a parking deck at work everyday and the popping is frequent. I can physically feel it under my pedals. Thoughts?
Thanks guys!
-Mary
Old Oct 12, 2006 | 07:40 AM
04BlackMaxx's Avatar
Hm, install some new struts, and do the resetprocedure...its somewhere on here.
Old Oct 12, 2006 | 07:59 AM
kamski's Avatar
.org extraordinaire
Take the MAF sensor and reverse it. You installed it backwards in the car.
Kam
Old Oct 12, 2006 | 08:08 AM
clayman88's Avatar
In regards to the CEL, there may be an air leak somewhere along the joints of the intake. Try check all the joints and make sure they're all tight and there are no gaps. Then you may need to have the CEL reset. This is fairly common when installing intakes the first time.
Old Oct 12, 2006 | 08:53 AM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
come on, you cannot install the MAF the wrong way, the screws won't match up.
the CEL will go away in a matter af a week or less if you keep it on,
if you don't wanna wait just go to the nearest Auto Zone and ask for their scanner and clear it for free.
its no big deal, eventually it will go away if everything is on properly.
Old Oct 12, 2006 | 09:19 AM
kamski's Avatar
.org extraordinaire
Not if he has the one where you keep the stock MAF body, yep u have Fujita. She has injen and a cute cat
Kamski
Old Oct 12, 2006 | 09:32 AM
Glude's Avatar
Ive prolly switched my intake setup over 6 or 7 times and not once have I gotten a CEL. I do see this a lot though and wonder how u guys manage to trigger it.
Old Oct 12, 2006 | 10:56 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
What Tek said above, most times the CEL light will come on if you installed your CAI with removing one of your battery terminals. Go to an Autozone and have them clear the code, if it is truly a problem, the light will come back on!!!
As for the popping sound, sounds like a bad strut. Stand parallel next to each front wheel, place both hands on your hood over the wheel and push straight down hard and release, the car should rise and stop. If it looks bouncy, your strut is most likely blown. Another potential problem may be if you have lowering springs, they where improperly installed, this problem is more evident with Eibach lowering springs...
Old Oct 12, 2006 | 10:59 AM
MK101's Avatar
I will def play around with it tonight- any other opinions of the popping?
Old Oct 12, 2006 | 11:01 AM
MK101's Avatar
Just got this- I will def check.
Old Oct 12, 2006 | 11:17 AM
MK101's Avatar
I can confirm that the way it is put on now is the only way it will fit.
Old Oct 12, 2006 | 12:12 PM
kamski's Avatar
.org extraordinaire
Pics?
Kam
Old Oct 12, 2006 | 12:20 PM
MK101's Avatar
Originally Posted by kamilkluczewski
Pics?
Kam
I will work on it- prob won't be until tomorrow though. Im moving tonight- feel free to come and help!!
Old Oct 12, 2006 | 06:34 PM
xoomer.com's Avatar
I Donate! Why Don't You?
I installed the Fujita myslelft while the battery was disconnected. Finished the install and connected the battery. Lots of noise from CAI and no "CEL" light. So far so good. Boy this noise is addictive even thou my MPG plunged.
Old Oct 12, 2006 | 09:04 PM
Ritz's Avatar
mpg should not drop, as long as long as you're improving the way the car breathes... ie- intake and exhaust.
Old Oct 12, 2006 | 09:22 PM
MisterSparkle's Avatar
don't gunn the engine man...lolxz i kno it shoulds great and all buh just don't! lolxz
Old Oct 13, 2006 | 05:19 AM
MK101's Avatar
My MPG has dropped as well... and I think what xoomer and I mean by that is that b/c we have been "trying to hear the noise" quite a bit we have consumed a little more gas than normal... right xoomer? haha! :P
Old Oct 13, 2006 | 09:30 AM
xoomer.com's Avatar
Right on the dot!!!. The sound is narcotic.
The hydro-lock still bothers me thou.
Old Oct 13, 2006 | 09:31 AM
MK101's Avatar
Hydro-lock?
Old Oct 13, 2006 | 10:04 AM
kamski's Avatar
.org extraordinaire
K, how positive are you the part (MAF TUBE) that connectes the Lower tube (down to airfilter) and upper tube (connects to throttle body) is not reversed?
I would unplug the battery and turn the key over to start, this drains the ecu. Then recconect the battery and restart the car.
But do this only after you'r 100% sure the MAF is installed correctly.
Kamski
Old Oct 13, 2006 | 10:11 AM
Ritz's Avatar
Hydro-lock?
hydro-lock is when you suck up a bunch of water through your CAI ... very bad for the engine so, avoid big puddles/lakes/oceans ...
Old Oct 13, 2006 | 11:09 AM
xoomer.com's Avatar
Bad for the engine...I like the mildness of it.....It's more like - YOUR ENGINE IS F-CKED
Old Oct 13, 2006 | 11:16 AM
madmik's Avatar
Hydro lock is a non issue with the NISMO CAI.
Old Oct 13, 2006 | 11:21 AM
Tek-Niq's Avatar
you don't have to worry about hydro lock with any cold air intake as long as you keep the wheel wells intact and not broken..
Old Oct 13, 2006 | 12:14 PM
xoomer.com's Avatar
If it wasn't an issue, it wouldn't void the warranty. Now you were saying..?
Old Oct 13, 2006 | 01:02 PM
Ritz's Avatar
finished my Fujita install... no SEL for me (yet) ... I'll update if I do get one...
Miket2006
Mar 1, 2021 03:55 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Forge277
Jun 13, 2016 09:26 PM
captchaos
Mar 15, 2016 12:18 PM
homeofbacon
Sep 23, 2015 07:17 PM
