Fog lite bulb is out
Old Nov 10, 2006 | 11:51 AM
gujucrave's Avatar
Driver side fog light bulb is out thinking about replacing both sides with a brighter bulb any ideas on what kind and the size I would need?
Old Nov 10, 2006 | 11:55 AM
BrainDfect's Avatar
you should go with the HID kit. you would need the h3 bulb
Old Nov 10, 2006 | 12:03 PM
gujucrave's Avatar
BrainDfect doesn't the HID kit come with a bulb?
Have you done this on your MAX?
Old Nov 10, 2006 | 03:43 PM
I VIK I's Avatar
Yellow lights are good! the match the color of Dosa
Old Nov 10, 2006 | 04:07 PM
muskrat20's Avatar
Sylvania make the silverstar. I replaced the fog lights on my car with them and there is a noticable difference in the whiteness/brightness. The silverstars burn at approx. 4000 degrees kelvin and regular halogen in the range of 2800 - 3200 kelvin. I don't have the box anymore but I think the model number was H3T and they should cost about $15-$20 each. Just be careful not to touch the bulb cause it can cause a shorter life span or the bulb may even crack....
Old Nov 10, 2006 | 04:41 PM
AnDyMaN's Avatar
silverstars if you want cheap good replacements, HIDs if you wanna be ballin! lol, just remember to not touch the bulb, if you do, rubbing alcohol and lint free cloth (maybe a different cloth?).
Old Nov 11, 2006 | 04:20 PM
xoomer.com's Avatar
I Donate! Why Don't You?
My went out too. Anyone know what is the temperature of stock HIDs?
Old Nov 12, 2006 | 08:07 AM
04BlackMaxx's Avatar
If you already have HID, doing HID in the fogs, besides being a complete PITA is overkill IMO....In my experience every aftermarket colored H3 burned out in a month and I went back to stock cuz im sick of taking apart theintake to get at the bulb.
Old Nov 12, 2006 | 12:52 PM
Killah Kane's Avatar
Mine went out to. Can someone pleaseeee put together a detailed instruction sheet the steps we need to do in order to access the fog bulbs to replace them? I know we need to remove the fluid resevoir and air filter housing but could someone clarify how to do this? I dont want to do it wrong or put it back together wrong....
Old Nov 12, 2006 | 02:18 PM
I VIK I's Avatar
What aftermarket HIDs are recomended for the fogs, and I belived the stock headlights are 3800K is that correct?
Old Nov 12, 2006 | 03:16 PM
CanadianMoFo's Avatar
Stock HID is 4300k. I replaced my fogs with a 6000k H3C HID kit. Looks fantastic.
CM
Old Nov 13, 2006 | 01:20 PM
xoomer.com's Avatar
CM
How much ****? and where?
Old Nov 13, 2006 | 03:06 PM
Got my kit in the CoWay group buy. There are a couple group buys going on for HID kits in that section.
Old Nov 13, 2006 | 06:20 PM
haasem's Avatar
Driver fog light out
I too just noticed that my driver side light is out. 9 months 20k miles and it is gone. I am looking in to alternate bulbs. The OEM do not do much. I only use them to make the zenon headlamps less harsh.
Old Nov 15, 2006 | 04:45 PM
markmaxima's Avatar
i agree you should get a hid kit for a h3 bulb, or superwhite
Old Nov 15, 2006 | 04:46 PM
markmaxima's Avatar
and you do know you have to take the whole headlight out to change the foglight bulb
Old Nov 16, 2006 | 08:27 AM
xoomer.com's Avatar
WTF, You serious?
Old Nov 16, 2006 | 11:35 AM
I call BS on this from personal experience. I replaced my fog bulbs without pulling the assembly. It's a tight squeeze, but do-able. You will likely have to remove the intake pieces at the drivers side, and the side cover and washer fluid filler tube on the passengers side to get access.
Certainly to install HID's you should remove the bumper and headlight assembly to install the ballasts in a good protected location.
Old Nov 16, 2006 | 12:13 PM
kamdigital's Avatar
in my exprerience the Silverstar H3 burn out pretty quickly, I had them in the fogs of my '99 SE and they didn't last long.
Old Nov 16, 2006 | 07:00 PM
No you dont
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
