Skunk2 IM Spacer
Old Feb 14, 2007 | 06:28 AM
  #41
NmexMAX's Avatar
dot dot dot ...
Originally Posted by xoomer.com
^^^ IAT ???, ECT ??? How did you measure?
Any data logging software.
Auterra, Autoenginuity, Cipher etc.
Old Feb 14, 2007 | 07:20 PM
  #42
xoomer.com's Avatar
I Donate! Why Don't You?
Thanks, con someone still explain the other abbreviations? I guess one is the temperature outside and the other is the air going through the CAI (MAF). Correct?
Old Feb 14, 2007 | 08:18 PM
  #43
eK9aT10pSi's Avatar
iat = is the intake air temp, its used to correct fuel quantity since air temps effects air density
and i believe
ect = engine coolant temp sensor goes into the coolant passage where it maintains constant contact with the coolant, from there teh PCM uses the ECT sesnor to read the temp
Old Feb 14, 2007 | 08:30 PM
  #44
xoomer.com's Avatar
and i believe
got it, I was just wondering cause I want to insulate my fujita cai and see the difference if any it would make.
On a side note: do you know if anyone has a tranny cooler installed on a 6th gen.
Old Feb 14, 2007 | 09:31 PM
  #45
!PrjctMax!'s Avatar
I was thinking about a tranny cooler a while ago, but many people on the org said that it would pointless unless you tow things, have a lot of power, or for some odd reason are just running a "hot" trans. It may also prevent the trans from heating up to its operating temperature which would cause bad things to happen. That's just what I've heard, so let the PROS chime in.
Old Feb 15, 2007 | 07:14 AM
  #46
xoomer.com's Avatar
Funny thing I just read some post on NYCMaximas and the guy was complaining about his tranny problem and half the people said something to the effect "you should have added tranny cooler"
When my Jeep tranny failed, I was told the same thing too.
Old Feb 15, 2007 | 07:50 AM
  #47
NmexMAX's Avatar
dot dot dot ...
A tranny cooler is cheap insurance.
Old Feb 15, 2007 | 08:17 AM
  #48
!PrjctMax!'s Avatar
So are there really any downsides to it?
Old Feb 15, 2007 | 08:18 AM
  #49
NmexMAX's Avatar
dot dot dot ...
Nope. . . . . .
Old Feb 15, 2007 | 08:23 AM
  #50
!PrjctMax!'s Avatar
Nope. . . . . .
hmmmm so will any tranny cooler do that is made specifically for our car, or is it "you get what you paid for?"
Old Feb 15, 2007 | 08:36 AM
  #51
NmexMAX's Avatar
dot dot dot ...
I realize these are for the 4th gen, but this model fits the 5th gen as well. Not sure about the 6th gen. It would take a little leg work on figuring out where to mount it (dimensions etc) and also what model you would want. Some have temp readouts, some are as plain as day.
http://forums.maxima.org/showthread.php?t=370111
http://forums.maxima.org/showthread.php?t=449789
http://www.greghome.com/Greg's%20Garage/1999%20Nissan%20Maxima%20SE/Xmission%20Cooler.htm
Old Feb 15, 2007 | 08:40 AM
  #52
!PrjctMax!'s Avatar
I realize there are for the 4th gen, but this model fits the 5th gen as well. Not sure about the 6th gen. It would take a little leg work on figuring out where to mount it (dimensions etc) and also what model you would want. Some have temp readouts, some are as plain as day.
Thanks!
Any opinions on the Stillen kit for the 6th gen? http://www.stillen.com/news.asp?id=21
Old Feb 15, 2007 | 08:41 AM
  #53
NmexMAX's Avatar
dot dot dot ...
Looks like a quality unit. IMO, a tad small.
Old Feb 15, 2007 | 10:56 AM
  #54
xoomer.com's Avatar
Thanks!
I was told you can just pickup one at autozone and it will do its job. Mouting it might be a different story but I think if one was to get a longer one it would easily fit behind the grill.
Old Feb 15, 2007 | 10:57 AM
  #55
!PrjctMax!'s Avatar
orly? What's the price from autozone?
Old Feb 15, 2007 | 11:01 AM
  #56
xoomer.com's Avatar
By longer I meant
rather than
please excuse my ASCI drawings,
Old Feb 15, 2007 | 11:05 AM
  #57
!PrjctMax!'s Avatar
By longer I meant
rather than
I got that part. lol But what is the price from autozone?
Old Feb 15, 2007 | 11:22 AM
  #58
xoomer.com's Avatar
Autozone has a universal one, the cooler itself is 12 x 7.5 x .75 and it costs $40 (Part # 911403)
I haven't seen it so don't know if it comes with clamps, hoses etc but these shouldn't be expensive.
Old Feb 15, 2007 | 11:45 AM
  #59
xoomer.com's Avatar
http://www.usa-trailer-hitches.com/t...FQ_ASgodB3o6pg
I guess this would be on a fancy side with automatic temperature control.
http://www.autoanything.com/coolers/65A3050A0A0.aspx
incubusjohnny
Nov 3, 2015 05:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Maxboy23
Sep 4, 2015 06:04 PM
Maxboy23
Aug 11, 2015 11:59 AM
