Why are there two muffler tips?
Why does the 6th gen mufflers have two exhaust tips while most other
cars have one? Are the two tips from the same opening or the design
is similar to the 5th gen where one would only open up at a higher load?
They are "HIGH CAPACITY" mufflers. I think they do have valves inside like 5th gens. I replaced all stock piping, resonator, and added y-pipe; and I notice that above 3k RPM is quiter than at lower RPM. And quad tip is badazz...
Could you give me more details on the piping size ? and also maybe a Sound Clip ? Does it give that Altima SE-R groar ?
Originally Posted by 04BlackMaxx
I think it looks better, its done for looks, nothing more, nothing less.
These two pipes also have the advantage of very slightly reducing the back pressure on the whole exhaust system.
Dont want to burst your bubble about Quad Tip exhaust but in reallity, unless you have a dual pipe from the collectors system... it basically sucks and is only for esthetics.
http://www.nissanperformancemag.com/...revenge_nerds/
So if you have on big pipe out of both collectors and then run to one outlets. You can get some serious performance.
Check out a true dual exhaust setup and its gains.
http://www.nissanclub.com/forums/eng...test-pipe.html
Live outside and .org and learn also youg one.
Kamski
Kamski
Kamski
Kamski
Originally Posted by !PrjctMax!
ale kurwa crazy! I doubt there's enough room for that being done on the Max and the money would be an issue too
Damn exhaust parts are expensive.
Kamski
Originally Posted by SilverMax_04
Basically this is correct. It is one of the few indications on the outside of a 6th Gen that you should be careful before you mess with this 4-door car. These 2 pipes indicate that the breathing of the engine should be better than in a 4-door Accord that only has a single pipe.
Really, do we have any side by side pics to compare the underbody?
Kamski
Kamski
CAN THIS BE USED FOR A MAXIMA? 05?
Kamski
Kamski
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
You will need to make the C-pipe longer but it would end up almost the same product in the end.
